Turn the ign on all the lights on the cluster come on as normal, wait about 3 seconds and i hear my megasquirt relays and my ABS all click(turning off) and all the lights on the cluster disapear except the service light. Ignition switch tested good and is putting out at all the wires.
Keep in mind i have no ECUs, this thing worked flawlessly until tonight when i turned my ign on it did this, i did not unplug anything, the car was working then it simply wasnt.
Is there a main relay somewhere that controls main power? the red relay in the box (i think its fuel pump) kills all power to the cluster when removed, i pulled the case off it and manually engaged/disengaged it and when engaged it does the same thing (ign powers on for 3 seconds then shuts off)
Gurus please chime in, this is the last thing i need right now
tia
robbie
edit: fyi obviously the battery has a full charge.
When the power cuts off it is a very sharp cut, just as if a relay was cutting it off, ive checked all grounds, weird thing is it just started happening out of the blue.
