Fog Lights
8 replies to this topic
#1 DTALS
DTALS
  • 7 posts
Posted 20 February 2010 - 11:32 PM
I would like to add factory fog lights to my 1998 S70. Are the wires already installed and I just need lights and a switch? Has anyone done this already?
#2 volvoskiah
volvoskiah
  • 1,298 posts
Posted 21 February 2010 - 01:10 AM
you need a J relay and another headlight relay, a switch, fog lights, and mounting hardware. fairly simple, I did mine a few years ago.
98 S70 GLT-M * 79 242 GT * 96 850R * 84 F150 * 99 S70 AWD
72 Chevrolet K10 Cheyenne*78 242 GT*98 S70 T5*00 V70R*04 V70R*96 855R *97 855R*98 V70R*98 V70R*99 V70R*99 V70R*98 V70 NA*98 V70 XC
#3 --Aaron--
--Aaron--
    douche bag
  • PipPipPipPipPipPip
  • 12,546 posts
  • Gender:Female
Posted 21 February 2010 - 12:51 PM
To elaborate on that a little bit:
In the relay panel under the driver's side of the dash you need to add a 213 Relay and a J Relay. I have a .pdf with detailed instructions. Under the fuse box cover you need to replace your non fog main light control relay with one that is fog ready.
At that point you add the switch, the assemblies, take the fog wire clips out of their dummy plugs under each side of the front bumper and you're good to go.
The whole Genuine Volvo fog light kit for your car is somewhere between 200 and 250, pretty good deal IMO. That's the route I took.
#4 foxtrapper
foxtrapper
  • 13 posts
Posted 03 March 2010 - 11:04 PM
Any chance of you placing this PDF where we can find it? There's enough cars in the local junk yard for me to probably find the bits I'd need.
#5 foxtrapper
foxtrapper
  • 13 posts
Posted 04 March 2010 - 12:20 AM
Never mind,I found it.
#6 3gkvalvo
3gkvalvo
  • 16 posts
Posted 18 March 2010 - 10:33 PM
the 213 relay, does it have that number? and what color is it? i can not find one with that color, my fog lights do not work with the j relay only, will an all purpose relay works?
#7 Tom.
Tom.
    LONGTOM
  • 2,916 posts
Posted 18 March 2010 - 10:46 PM
its a jumper really... white top green bottom thats the J relay youll need as well found in the same panel
00 Olive V70R -- 98 S70 T5M
#8 3gkvalvo
3gkvalvo
  • 16 posts
Posted 19 March 2010 - 01:51 AM
thanks a million volvo for life, it works and my s70 is looking better everyday, next will be the complete turbos connections from ipd all in blue. thanks again for the support and great help. pictures can always tell the complete story.
oc
#9 Anatoli
Anatoli
  • 731 posts
Posted 20 March 2010 - 02:57 AM
adding fog lights to my 95 850 base. Sourced a grey 104/108 relay, white/green 213 relay, j relay and a switch.
Installed everything but the fogs. put the negative battery cable back on. no fogs installed yet.
Switch is working, I tried it on another car with fogs.
now i turn the ignition to pos II and press the switch and nothing happens on my car.
So either the relay is bad or, another crazy idea, I need actual fogs to close the circuit.
anyone could comment?
(03 V70 2.4i at -- 17X kmiles)
(00 v70XC FWD LPT at -- 18X kmiles)
