* * * * * 1 votes
Manual Transmission Throttle Cable
23 replies to this topic
#1 Hanks
Hanks
  • 3,374 posts
Posted 26 February 2010 - 06:08 PM
the cable has more travel and more control. also it gets rid of the kickdown spring inside the cable.
all cars have the extra spot for the manual cable.
edit:
i just ripped out the auto one from the firewall and broke it since i didnt need it anymore. inside the car its very simple how it comes off the pedal, just slide the ball out of the clip. the just install the new one... you have to push pretty hard to get the clips to grab onto the firewall from the engine bay side.
#2 Fake-R
Fake-R
    Rarest Member Ever
  • 2,169 posts
  • Interests:Pushing envelopes.
Posted 26 February 2010 - 06:33 PM
And what does it do? :unsure:
Will it take away the stupid long shifting rev thing it has going on?
-1996 850 Turbo
-2007 XC90 V8
#3 GeraldJ
GeraldJ
    Professional Cow Fister
  • 1,496 posts
Posted 26 February 2010 - 06:36 PM
Is it really going to make that much of a difference?
'96 855, Koni yellows, ipd springs, TT-USB
Eagle H-beams, Weisco pistons, custom cams
GT3071R, 60lb/hr injectors, Ported R Mani, W2A intercooler
m56h, 707 clutch, P&P'd head, CAI,
#4 Hanks
Hanks
  • 3,374 posts
Posted 26 February 2010 - 07:20 PM
i believe thats part of the ecu... ill check this weekend.
yes :)
#5 ozzimark
ozzimark
  • 4,349 posts
Posted 26 February 2010 - 07:34 PM
Part number 9157600?
I already have the manual throttle cable, but since it came with the car, it's developing cracks in the outer sleeve that bother me :lol:
#6 Hanks
Hanks
  • 3,374 posts
Posted 26 February 2010 - 07:43 PM
yup thats the part
#7 matt b
    Earth day- Every day
  • 14,420 posts
Posted 26 February 2010 - 07:46 PM
yes :)
That's correct, it has nothing to do with the cable. It's ECU related.
MY97 855 Manual swap, Porsche Brakes, 16T on LPT block and plenty of IPD parts
#8 bergmjs
bergmjs
  • 1,920 posts
Posted 26 February 2010 - 08:23 PM
Should this get tacked onto the manual swap sticky?
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
#9 matt b
  • 14,420 posts
Posted 26 February 2010 - 08:26 PM
I added it, thanks for reminding me.
#10 Hanks
Hanks
  • 3,374 posts
Posted 26 February 2010 - 08:31 PM
sweet
#11 mune237
mune237
  • 985 posts
Posted 26 February 2010 - 08:35 PM
I haven't dug into my 2000 C70 this far yet, but does this affect 99+ cars?
I'm not sure if my '00 even has a throttle cable, does it? HaHa
I bought this '00 C70, drove it home, parked it in the shop.
But I've spent hundred$ on new parts for it. Even have a low mile M56H for it.
The warmer the days get, the more enthused I get to rebuild it though.
1995 960 TOTALLED
1997 850R SOLD
2000 C70 HPT Convertible
#12 tchnprgrmr
tchnprgrmr
  • 246 posts
Posted 26 February 2010 - 09:02 PM
99+ has the ETM, no throttle cable
I'm not sure, but i believe the ME7 cars need to have the ecu retuned for a manual swap.
1999 C70 2.4 LPT Convertible
19T, 0.5 bar actuator, 3" turbo back exhaust, InMotion tune, fmic with 2.5" piping, ME7 NA intake manifold, snabb IM spacer, ebay BOV, catch can, japanifold exhaust, EBC, weitec lowering springs, euro plate, no cat, single dual output muffler, e-code headlights, dual transmission coolers, polyurethane mounts, front strut bar, Innovate wideband
#13 lookforjoe
lookforjoe
  • 8,304 posts
  • Interests:Making Stuff
Posted 26 February 2010 - 09:27 PM
I'm with you on that - I like things to be just so, and cracks in the casing ain't one of them :lol:
#14 lookforjoe
lookforjoe
  • 8,304 posts
Posted 26 February 2010 - 09:34 PM
I can see that using the outer bobbin will give more precise throttle control, since it's moving further away from the pivot point, but have you checked to see if it actually opens the throttle further? After all, it's only 90º maximum. I've never checked mine (auto cable) with a helper to see what the widest angle is via cable from the gas pedal.
#15 ovlovturbo
ovlovturbo
  • 522 posts
Posted 26 February 2010 - 09:47 PM
any chances of a install write up? with some pictures and stuff like that?
1996 850 turbo wagon
19t, 5 speed swap, 3in exhaust, etc, etc, etc
Many thanks to my good friend M.K
#16 Hanks
Hanks
  • 3,374 posts
Posted 26 February 2010 - 09:57 PM
it cant open it further. any further and its going to the other way aka closing :P
ya ill take some more pics tonight and update the thread. its very easy. 10mins max...
#17 ovlovturbo
ovlovturbo
  • 522 posts
Posted 26 February 2010 - 10:02 PM
cool thanks! looking forward to seeing it
#18 ozzimark
ozzimark
  • 4,349 posts
Posted 26 February 2010 - 10:13 PM
I dunno about yours, but my throttle pulley has two stops on it, 90º apart, one that acts as the resting point when your foot isn't on the pedal, the other prevents you from flooring it too far, and closing the throttle again.
#19 lookforjoe
lookforjoe
  • 8,304 posts
Posted 26 February 2010 - 10:35 PM
Hi
I'm aware of the base stop for the bobbin.
There's a stop on the throttle plate lever; it can't open past 90º no matter what the bobbin/cable do.
Posted Image]
the question is whether the cable properly adjusted, can actually open to the full 90º with either setup. The only obvious difference is better modulation due to improved leverage on the outer track.
#20 Hanks
Hanks
  • 3,374 posts
Posted 26 February 2010 - 10:39 PM
the way that the throttle cable mounts to the bracket you wouldn't be able to install it on the the smaller side of the throttle. it would come in at too much of an angle and rub
