Secret To Removing V70 Rear Bumper Cover?
Started by sconeman, Feb 26 2010 10:57 PM
6 replies to this topic
Posted 26 February 2010 - 10:57 PM
maybe I suck at searching but I really need to know if there's an easy way to remove the cover only on the rear ..seems like you either have to break it or pull the whole bumper..?
850 Project
SHORT SHIFT KITS---------- TURBO INTAKES---------- SHIFTER CABLE BUSHINGS
Posted 27 February 2010 - 02:48 AM
Theres pry a couple ways
- Drill pop-rivets from inner fender cover
- Unbolt two bolts from crashbar (look under the car) 15mmish Bolt
- pull bumper straight out (or do you push the bumper in and then pull out each side?)
- Lay bumper down and undo millions of torx to remove the crashbar (if you want)
02 S60 T5M
Posted 27 February 2010 - 04:44 AM
same as the front bumper ...
Posted 27 February 2010 - 06:30 AM
one of my better contributions to VS:
2000 V70XC SE, 149k '00 R Duals/Angled 15G/15 psi ST T5 tune/Delco TCV/UK 302s/180°F Stant Superstat/Samco hoses/IPD HD CBV/Sconeman intake
1998 S70 T5, 135k '00R 302s/Delco TCV/IPD 3" Turboback(taken off the road)
1998 S70 T5, 223k DIY AEM BCS/IPD Stage 1 ECU
Check out the Delco BCS/TCV
Posted 27 February 2010 - 02:29 PM
850 Project
Posted 27 February 2010 - 06:53 PM
out of curiosity is this the same for S70's?
Tom - 1998 V70T5M - 112K
