Methanol Kits And Colder Spark Plug
28 replies to this topic
#1 Chow
  • 57 posts
Posted 12 March 2010 - 05:41 AM
I'm looking for a place to get a methanol kit and part number for colder spark plugs (like either 2 or 3 stages colder) Can you point me in the right direction?
1997 850R Black "All go and no show"
16T turbo w/19T compressor wheel @18psi by "James" @ Performance Techniques , MBC, N/A Cams, "China" connecting rods, S60r Exhaust manifold/Green injectors/ Metal head gasket, SpeedTunning stage II download, 302mm Big Brake Kit, V70R rims, iPd intake, iPd turbo back exhaust, MSD ingition, Koni FSD strut & shock kit with iPd lowering springs, iPd front and rear swat bars, iPd strut brace, iPd heavy duty end links, and more to come.
#2 bjohn07
  • 74 posts
Posted 12 March 2010 - 06:47 AM
right now im running a coolingmist water meth kit u can check out there website http://www.coolingmist.com/
it comes with a boost switch so you can set when to start injecting the water, and i read on the pro shot fogger post that this ngk plug part#ngk r5671a-9 is 2 steps colder than stock
#3 HtownTurboBrick
  • 6,213 posts
Posted 12 March 2010 - 09:11 AM
NGK BKR7E part number 5791 at most auto parts stores.
~Jon AKA: the ddrunkn trigr hapy pumckin~
- '98 S70 T5M w/ '00 R motor swap 266whp/340wtq on 16T - 98' S70 T5 Black: Former DD new project - 96' 850 GLT -
RIP Joe Ng 02/29/56-08/18/05...
#4 550
    someone please talk to me
  • 9,367 posts
  • Interests:My two cars
Posted 12 March 2010 - 03:16 PM
To my understanding with meth/water injection you may actually want to run a hotter plug. Methanol injection should allow you to do this with out adverse effects because it will cool things down obviously.
#5 flaco
  • 557 posts
  • Gender:Not Telling
Posted 12 March 2010 - 03:44 PM
1-step colder plugs Id say for track use ONLY. You say 2-3 ranges? why?
98 S70 T5M, daily-driver running on megasquirt, 15psi
SOLD: 96 850 GLT 37k miles (yes, 37k miles), now at 63k miles ;-)
#6 bjohn07
  • 74 posts
Posted 12 March 2010 - 09:04 PM
on one of my volvos i can run water meth with 15ps and i still use stock plugs, i just gap em down to .024
#7 Chow
  • 57 posts
Posted 12 March 2010 - 09:44 PM
I was told that running the kinda boost I am now and more once I get my methanol kit, I would want to go with colder plugs.... Looking for 25psi if not a bit more 28psi
#8 550
  • 9,367 posts
Posted 12 March 2010 - 10:22 PM
You should make more power with hotter plugs, I believe.
Hey before you go to 28 psi on that pea shooter, why don't you try a real turbo?
Edited by 550, 12 March 2010 - 10:23 PM.
#9 cr854r
  • 894 posts
  • Interests:Club Racing, Auto X, Volvo
Posted 13 March 2010 - 01:16 AM
if your engine is producing a lot of heat, and you run to hot of plugs it will lead to detonation, but the cold ones fowl out faster, and will require more attention, so basically you need to figure out the right plug for the job, basically hot engine=cold plug, and cold engine= hot plug.... basically
Projekt R
-Megasquirt
, 18t, 3in turbo back, kw v2 coilovers, M56H, fmic, 16 point roll cage, corbeau seat/harness, gutted to hell, *solid bushings, *F/R sways, walbro 255, 450cc injectors, NA cams, willwood brakes, port/polished head, *rsi rods, *R mani, adjustable control arms, adjustable strut top mounts, adjustable sway bar links... etc etc
#10 550
  • 9,367 posts
Posted 13 March 2010 - 01:38 AM
Well ... methanol cools your engine down ... Thats the idea behind being able to run a hotter plug. Is the methanol injection does its thing.
Edited by 550, 13 March 2010 - 01:39 AM.
#11 Chow
  • 57 posts
Posted 13 March 2010 - 04:49 AM
If all goes well, the KKK24 is in the works!
#12 Account_Deleted_T5M
    I Was Pwned
  • 5,827 posts
Posted 13 March 2010 - 04:57 AM
k24 isn't a real turbo its still a pea shooter
Sorry to all the people who are still trying to get their money back.
#13 550
  • 9,367 posts
Posted 13 March 2010 - 05:00 AM
a K24 is a big turbo... for a stock engine. BUt a k24 is NOT that much bigger than a 19t. And even that being said, no one can really prove that the K24 is bigger than the 19t. It is all just theory from what I can tell as the wheels on the K24 are much larger, but also of a different design (Reminds me of a garret).
I'm talking gt30r status here. Or 50 - 55 trim turbos.
#14 Chow
  • 57 posts
Posted 13 March 2010 - 06:57 AM
Well right now I'm almost a 60 trim.... 58-59 trim and we sent out a kkk 24 and now its almost a 70 trim with the upgraded compressor wheel so I'm wanting to know what kinda numbers that will post
#15 550
  • 9,367 posts
Posted 13 March 2010 - 01:20 PM
What was the k24 upgraded with?
#16 dublin14
  • 2,519 posts
  • Interests:Track events in NASA/ProAutoSports and dumping money into old Vulva. And one of the VS mods on here put that comment above. Dam kids these days lol
Posted 13 March 2010 - 02:36 PM
The K24 will out flow a 19T anyday! Just look at the comparo that Spanky did in size between the 19T wheels vs the K24 which also has ETT. I found this which is interesting for the K24 guys! http://www.streetfir...urbo_199778.htm
#17 fischmama
  • 2,332 posts
Posted 13 March 2010 - 02:42 PM
I would agree with that, I just wish there where some flow numbers out there.
1998 Volvo S70 T5M - 04 R Motor - T3 60Trim @ 19PSI - 3" Custom Exhaust - TT - FMIC w/ 3" piping - TA Coilovers w/ Custom Rears
#18 dublin14
  • 2,519 posts
Posted 13 March 2010 - 02:51 PM
I am very interested to find out what you did and how much the shop charged. Im all ready to do an upgrade with the k24 i have sitting here.
#19 550
  • 9,367 posts
Posted 13 March 2010 - 03:07 PM
But by how much? I mean, really you cant just say that because the wheel is bigger it WILL flow more.
#20 dublin14
  • 2,519 posts
Posted 13 March 2010 - 03:12 PM
Well look at the bright side of that vid, a K24 can get 308awhp and 364trq to the ground. That would easily be 320+whp and even more trq to the ground with a FWD. Im sending my head out to make sure it flows as much as it can to let the engine breath as much as possible.
IPD
