Hello, After doing my research on this site (thanks to all who post on Volvospeed) I have came to the conclusion that I have a plugged pvc/oil separator issue. My question is can the oil separator be cleaned out and reused? I know the right answer is to replace it along with all related hoses but I am really cheap and thought if I could get by with just a $10 intake gasket and a couple hours of garage time that is the way I would go. Has anyone done this? or do I bite the bullet and and fork out the $100 to IPD for the new parts. Thanks in advance. John
Oil Separator
Started by johnmcm, Mar 15 2010 02:30 PM
8 replies to this topic
Posted 15 March 2010 - 02:30 PM
1998 Volvo S-70 non Turbo 140k miles
Posted 15 March 2010 - 02:45 PM
NOT a serviceable item.
Do the whole PCV tuneup for about $100 in parts because alot of labor is involved (removing the Intake Manifold etc.).
Don't be cheap, you don't have a choice.
Just stop drinking beer for a week then you have $100 (j/k).
1998 V70 Non-Turbo 100K miles
Posted 15 March 2010 - 02:49 PM
It's your call. These parts can definitely be cleaned out and reinstalled. The main issue wit that is really the hoses, they experience a lot of heat etc so they get old and brittle and can crack easily. No one cleans out and reinstalls the parts because it is quite a bit of work to take everything apart and reassemble. It isn't worth the hassle to know you are putting suspect parts back in. You won't necessarily know right away the instant an old PCV hose goes bad, whereas if you replace it then you can be pretty sure PCV parts aren't the cause the next time the car starts hiccuping.
I'd swap in new parts.
'96 NA 855 | 207 k | wrecked, body not fixable, runs and drives like a (slow) top
'96 NA 855 | 92 k | daily driver
You will get lots of opinions on this...Mine is: You can clean and reuse the separator itself if it is in good shape, but all the lines/connectors/tubes should be replaced. Last time I replaced mine, I cleaned it to see if it could be done adequately. I thought it looked fine. So I have a clean used one laying around
That being said, if you buy a kit vs parts you can likely get the separator for almost "free" so...
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted 15 March 2010 - 02:50 PM
Also, put the car model etc in your signature, helps people to know how to reply (is your car a turbo? they have more PCV issues than NAs).
Posted 16 March 2010 - 04:21 AM
Posted 16 March 2010 - 04:28 AM
Thanks all for the advice, I am going to sleep on it for a couple days and then probably get new parts.
Posted 19 March 2010 - 02:11 AM
aftermarket hoses suck! Buy the volvo brand you'll be glad you did!
