Rimps
Posted 16 March 2010 - 02:26 AM
http://www.jegs.com/...763970/10002/-1
but i can't find any. anyone know of something similar? can i get adapters and go for it? offset etc i know nothing
Posted 16 March 2010 - 02:32 AM
In any case the 17x9 will be too wide for your car, widest you can go without rubbing is probably 8". And, even with adapters, you can't really run a 24 offset wheel without some fender rolling. I think the generally accepted low number for the offset is closer to 30.
2011 Volvo S60 T6 AWD
Posted 16 March 2010 - 02:36 AM
probably more.
Posted 16 March 2010 - 02:39 AM
JVC, on 13 March 2012 - 05:56 AM, said:
Posted 16 March 2010 - 02:43 AM
Posted 16 March 2010 - 02:50 AM
Any wheel you want to run with an adapter has to have a high enough offset number such that even after factoring in the thickness of the adapter, you're still in an acceptable range. For example, Porsche rims generally have offsets in the 50's which is why people have successfully used them on Volvos.
Posted 16 March 2010 - 03:02 AM
Posted 16 March 2010 - 03:16 AM
Posted 16 March 2010 - 06:11 AM
Posted 16 March 2010 - 06:54 AM
(n)A-GAME, on 16 March 2010 - 02:32 AM, said:
+1 on that for sure.
my ride:'97 volvo 855R "the polär bäR" & a bunch of VW's.. ALLENTOWN, PA. 18104
Posted 16 March 2010 - 12:03 PM
To get a better feel, what are your favorite wheels from this selection?
http://www.tirerack....98&autoModClar=
Posted 16 March 2010 - 12:53 PM
#14
Posted 16 March 2010 - 02:52 PM
-1996 850 Turbo
-2007 XC90 V8
#15
Posted 16 March 2010 - 03:06 PM
OK, I'll play...
ASA AR1
#16
Posted 17 March 2010 - 07:46 AM
thank you! i had browsed tire rack before, the sport edition F7's are about the closest. i really didn't want to do pegs but we don't seem to have many options. i saw a dodge daytona with wheels similar to the torq thrust so i figured i should be able to find something in an appropriate offset, no?
#17
Posted 17 March 2010 - 10:21 AM
You will have to have the bolt pattern modified to 108mm, but they have qty 42 of the (TSW MONTAGE 18x80 5/114 ET40 HYPSIL) in stock now.These also come in black if thats your thing.
EDIT: Found chrome ones on ebay HERE which are even closer to the AR wheels.
'00 S80 T6 | '95 940T
#19
Posted 17 March 2010 - 07:19 PM
#20
Posted 19 March 2010 - 12:59 PM
You'll need adapters: found here.
And you'll need to do some fender work.
Really not a huge deal, but everyone here usually just puts on OE wheels, so there isn't any work involved.
