Finally Have The K24 Specs!
Posted 16 March 2010 - 02:28 PM
i
2474 spec. – 0.25 m³/sec – 37 lbs/min – 537 CFM
2480 spec. – 0.28 m³/sec – 41 lbs/min – 595 CFM
5324 123 2206: (possibly the 50mm you ask about?)
O.D. – 62mm with extended tip / Inducer – 49.6mm
As for this 5324 123 2206 being available… it appears to be available to us, you will just need to request pricing as it’s not been sold here in the U.S. yet.
The 2474 is what the North American S60R K24s came with (i dont know about Euro S60Rs). The 2480 is an upgrade that im going to order unless i can find something bigger.
A 19T is a 495cfm Turbo vs the K24 2474 which is 537cfm which is the same CFM as a 16G. The upgraded 2480 K24 wheel 595 CFM slightly out flows an 18G.
Im going to upgrade my K24, just not sure which way yet.
Posted 16 March 2010 - 02:33 PM
thats food for thought.....mmm tasty
thanks for finaly finding these specs...
long live vanessa 2.0!
Posted 16 March 2010 - 02:44 PM
1997 850R SOLD
2000 C70 HPT Convertible
2001 Chev Silverado 2500HD CrewCab 6.0L
Posted 16 March 2010 - 02:52 PM
Posted 16 March 2010 - 03:18 PM
This is really interesting, I know that the big 50 flows somewhere around 680cfm or 48-50lbs/min. The problem you run into when comparing one manufacture to another is that there is so many different variables. I have seen some companies say that their 50 trim will flow 52lbs/min and others say 48lbs/min.
When it comes to the k24 turbo, is there as much after market for it as others? Different turbine housings, different A/R's, or different trims available?
Also I have heard that the k24 doesnt hold up well to high boost pressures.
'96 855, Koni yellows, ipd springs, TT-USB
Eagle H-beams, Weisco pistons, custom cams
GT3071R, 60lb/hr injectors, Ported R Mani, W2A intercooler
m56h, 707 clutch, P&P'd head, CAI,
Posted 16 March 2010 - 03:20 PM
also will make them cheaper since now with all the totaled Rs out there , kinda dime a dozen
Posted 16 March 2010 - 03:25 PM
I keep hearing this but it seems that not many have looked into bolting on a garrett.
Did you know that a t3 housing from the early Volvo will bolt onto a t3/t04 garrett and then there isnt much need for an adapter or maching work.
Then all you need is a $25 oil feed and some banjo to hose barb fittings for the water. The oil return is dead simple also, use the lower half of the stock return and some high temp oil safe hose.
Posted 16 March 2010 - 03:37 PM
And agreed with Justin, the other thing is I believe a K24 will behave better than a uncontrollable 19T all day long...
Posted 16 March 2010 - 03:39 PM
I agree with you but with the k24 there is no modding needed just buy the parts from the dealer bolt it in and go ...
Posted 16 March 2010 - 04:09 PM
GeraldJ, on 16 March 2010 - 03:18 PM, said:
The spec on the HRC is: TDO6H-20G-14CM2 650 CFM
I'm thinking maybe I should look into the 25g, if I can get my timing issues properly addressed
1998 V70 XR M66 10cm2Hotside/Garrett 60-1 Built T5 Motor '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DP back Dual Magnaflow 14834's May 2011 355WHP(@6400rpm) 347WTq(@4400rpm)@22psi Now with LGSpeed Header & Custom Intake Manifold! BIG 31x12x3"FMIC Currently sporting a vented piston!!!
Posted 16 March 2010 - 05:32 PM
550, on 16 March 2010 - 02:38 PM, said:
42CFM isn't that big of a difference.
Its not a "huge" difference i agree.... but as i said a few days ago, if you compare a 16T to an 18T at a 50cfm difference, an 18T maxed is usually good for 30whp more over a 16T maxed! So for most guys on here that want a bolt-on Volvo Turbo, a K24 is the best choice for HP gain. If a 19T can get 290-300whp maxed out, and if a K24 gets 320whp (with proper tuning/supporting mods of course) then that makes for some very fast 850/S70's. We already saw V70R getting 308AWHP and 364WTRQ out of a stock K24.
#14
Posted 16 March 2010 - 05:38 PM
#15
Posted 16 March 2010 - 05:40 PM
#16
Posted 16 March 2010 - 05:49 PM
It is a fairly easy install; however, it isn't quite a direct bolt on like the 19t as the compressor side will hit the coolant pipe (at least - 98). It either needs to be bent to fit (can break) or newer style coolant pipe will need to be used.
1998 Volvo S70 T5M - 04 R Motor - T3 60Trim @ 19PSI - 3" Custom Exhaust - TT - FMIC w/ 3" piping - TA Coilovers w/ Custom Rears
#17
Posted 16 March 2010 - 06:21 PM
JCviggen, on 16 March 2010 - 05:40 PM, said:
I would love to find out from all the Modded S60R owners that Run 20PSI and see if thats really true. I have known of a bunch of modded S60Rs and modded S60 T5s that have never had issues with the K24. But i guess you have seen some go.
#18
Posted 16 March 2010 - 06:30 PM
#19
Posted 16 March 2010 - 06:37 PM
#20
Posted 16 March 2010 - 06:42 PM
Captain Bondo, on 16 March 2010 - 06:30 PM, said:
Luckily most of these compressors they are talking about were designed for use in an OEM 5-cylinder whiteblock turbo application.
Still though, this discussion should end before comparing to outside manufacturers.
Unless we have compressor maps in lbs/min or kg/sec it's very difficult to compare apples to oranges. It's even a stretch to try comparing the K24 to any TD04HL's with no data.
