So Suppose You Have Worn Valve Stem Seals...
Posted 19 March 2010 - 02:10 AM
But if the exhaust valves are worn too, I'm wondering if there might be exhaust gases blown past the valve stems into the cam compartment, which is part of the oil system? Now, you might say, no, because the exhaust stroke happens with the exhaust valves closed. Good point! But there certainly is never vacuum in the exhaust, right? And there is even back-pressure there, surely, during the rest of the cylinder cycle, particularly with a stock exhaust, and particularly in California... So my totally uninformed, armchair hypothesis, is that worn exhaust valve stem seals could lead to increased pressure in the oil system, and hence the same sorts of symptoms associated with clogged PCV stuff: oil oozing out here and there, some smoke out the dipstick tube, . . .
How wrong am I?
Mark
(BTW, I am going to do an in-car valve-stem seal replacement, and will document it here, where you can see my plans now...)
Posted 19 March 2010 - 03:10 AM
I think it would be difficult to push that much volume and air pressure between such a tight fit, even with valve stem seals that are hard as a carp.
I dunno though
Posted 19 March 2010 - 01:53 PM
Ihatespeedbumps, on 19 March 2010 - 03:10 AM, said:
Posted 20 March 2010 - 05:38 AM
Hoping to get her back together tomorrow---fiddling the keepers back in is a real ... assertive woman. Any tricks? I've been using a small magnetized screwdriver and an unmagnetized one, a gob of grease on the keeper, and then hope I get lucky. Only 20 more keepers to fiddle in...
Mark
Posted 20 March 2010 - 06:41 AM
http://sites.google....ct-updates/day1
Posted 21 March 2010 - 04:13 AM
Posted 21 March 2010 - 01:57 PM
So I take it the blue smoke after idling has gone away?
Posted 21 March 2010 - 04:25 PM
Yes. There are before and after videos in the write up so you can see the big difference.
Posted 21 March 2010 - 07:09 PM
Posted 21 March 2010 - 08:29 PM
Yeah, it would be easier out of the car. For me the alternative was to get a new head. This was certainly cheaper, but probably no less work.
Posted 21 March 2010 - 08:31 PM
If I read you correctly and also from experience the cam sprockets don't need to come off the shafts, right?
whoa, on 21 March 2010 - 04:13 AM, said:
Posted 21 March 2010 - 08:40 PM
Thanks!
Well, the sprockets do eventually have to come off, since you have to press in the front-end camshaft seals during reassembly. Next time I would wait until after the bolts come out at the other ends of the shafts, though.
Posted 25 July 2010 - 01:42 PM
I'm the guy who bought the tools off whoa and wanted to comment on this job.
1. This will fix a smoking at idle 850 which is not from a blown turbo (diagnose by much oil in intercooler), bad rings or bad valve guides. The valve seals looked to have been re-used in a cheap ebay rebuild ($300 rebuilt head last year).
2. I highly recommend this to be a two man job. There is plenty to keep two busy and operating the schley tool really should have a dedicated person. It was helpful when replacing keepers to be able to call, "half way up, no back down, up.....". We used 4 ft of cheater pipe on the schley handle and this made things much easier.
3.Take your time on cam cover removal. This is the riskiest part of the job, IMO as you can crack the head where the shafts fit in.
4. Cover all the open holes, including the intercooler piping in back and handle the keepers over the head only. We still had two runaways, one dropped in the engine compartment and another made a break for it and shot out of the head and fell downon the cross member heat shield at bottom.
5. I highly recommend the compressor method for securing the valves using a spark plug hole fitting that can be purchased almost anywhere cheap. The rope trick for us was tricky and the rope got stuck I think 4 ways on the first cylinder. We switched afterward to air.
6. Special implements: I had a dental pick for helping free the keepers which was awesome and also for helping manipulate the keepers back in after seal replacement. Also for keeper replacement using a long slender screw driver and some thick grease gun grease. Put a very small amount of grease on the screwdriver tip and stick the keeper to it and put it in with dental pick or other tool in other hand. Also, have a small diameter telescoping magnet that will fit inside the schley tool for valve keeper retrieval.
Again, I really call this a two man job. We did it in a long day (11 hrs incl lunch). Other skills required are timing belt removal/replacement skills. TDC on #1, crank shaft gear mark lined up on the block and slots on the camshaft ends level with head suface, exhaust slot cheats below the centerline, intake cheats above.
It was very rewarding to take this car back from being a smoking embarassment (it was bad and came on almost immediately) to a fine runnning car again.
#14
Posted 25 July 2010 - 02:24 PM
Edited by TorqueSteer, 25 July 2010 - 02:24 PM.
#15
Posted 25 July 2010 - 03:52 PM
TorqueSteer, on 25 July 2010 - 02:24 PM, said:
There is a specific procedure to get the sprockets on at factory angle. It does affect the precise timing angle of both camshafts. You use a camshaft-locking tool to lock the slots on the rear of the shafts to horizontal position, put the cam sprockets on loosely, install the belt and tensioner, press the belt hard twice at the top (between sprockets) and left (between water pump and exhaust sprocket), and then tighten the sprocket bolts to 15 foot-pounds.
If you don't have the cam locking tool, try to get the slots horizontal with the belt well seated in each sprocket, and then tighten the bolts. Installing the sprockets in the middle of their range of slop is probably an okay hack.
#16
Posted 25 July 2010 - 04:39 PM
So there is a top and bottom to the sprockets? They seem to be circular to me. I have sprockets with absolutely no timing marks and I am mating them to a set of new camshafts.
I am referring to the process of physically bolting the sprockets to the camshafts, before the belt is on and any timing has taken place.
I am looking at the sprockets, and I see three eccentric holes on them, and they are all spaced evenly. So there are 3 ways (directions) to attach them to the camshaft, the only distinguishing mark is a "M" engraved at the bottom of the gear.
I had assumed that since the gears appear to be circular and symmetrical, that I can bolt them on at any one of the three possibilities. I just wanted to make sure before I do this job tomorrow.
I have the cam locking tool.
Edited by TorqueSteer, 25 July 2010 - 04:54 PM.
#17
Posted 25 July 2010 - 09:48 PM
#18
Posted 25 July 2010 - 10:05 PM
whoa, on 25 July 2010 - 09:48 PM, said:
Ok I thought the same, just wanted to confirm. Thank you!
#19
Posted 26 July 2010 - 03:35 AM
#20
Posted 26 July 2010 - 06:20 AM
Gilhuly, on 26 July 2010 - 03:35 AM, said:
Thanks for the reply! Have you taken off the large black stabilizer bracket on the side of the engine in order to make and attach the cam locking tool?
