Fog Lights Into An 95 855 Base Made In 01/95 In Ghent Belgium
5 replies to this topic
#1 Anatoli
Anatoli
  • 731 posts
Posted 20 March 2010 - 04:32 AM
i'm somewhat confused if I can put the fogs, and if the car is prewired for them. 95 855 Ghent Belgium made in 01/95.
switch is there and the wiring is there plugged into blanks.
(03 V70 2.4i at -- 17X kmiles)
(00 v70XC FWD LPT at -- 18X kmiles)
#2 r850glt
r850glt
  • 1,343 posts
  • Crew:ECC
Posted 20 March 2010 - 10:03 PM
Remove the drivers side lower steering cover. you should find a yellow connector attached the the steering shaft. If it is there you can install the factory foglight kit Plug & play
2000 Mercedes W210
1995 854 NA Auto
RIP - Dad - M.G.T 10/31/42 - 12/03/05 "Press On"
#3 Anatoli
Anatoli
  • 731 posts
Posted 20 March 2010 - 10:58 PM
so you are saying basically that I do not need a new grey headlight relay, 213 Fog plug relay and and auxiliary "J" relay in 201 position.
Instead I need to use different relays, correct?
#4 Anatoli
Anatoli
  • 731 posts
Posted 20 March 2010 - 11:09 PM
this is pretty recent from 2010.
On page 2 there are pictures of the blue relays.
Is it the item you meant in your reply?
http://volvospeed.co...llation__st__20
#5 DVolvoguy850T5
DVolvoguy850T5
  • 340 posts
Posted 21 March 2010 - 02:48 AM
http://volvospeed.co...661-fog-lights/
Click link. Good start there. There is a PDF in this site some where that tells how and what you need. I just need the flow for the parts! :monkey:
I have a 97 855T5 now, have had 6 other Volvos in the past. Sux I aint got um any more!
#6 Anatoli
Anatoli
  • 731 posts
Posted 21 March 2010 - 05:09 AM
that's what I did and according to Vadis that's how one is supposed to proceed with late 95, 96,97 models.
For 94, early 95 the route seems to be different. that's what the first guy was talking about.
