I don't have a vacuum nipple on the intake manifold, so do I just cap off the connection on the fresh air tube?
Quick Pcv Question
Started by HPTDoh, Mar 22 2010 05:39 AM
4 replies to this topic
Posted 22 March 2010 - 05:39 AM
Posted 22 March 2010 - 02:45 PM
What are you doing?
You have two vacuum nipples on the far driver's side of the intake manifold pointing forward. My 1994 855T has no nipple on the far passenger side of the intake.
1994 Volvo 850 Turbo Wagon, 155K miles
Posted 22 March 2010 - 07:14 PM
yes, no adverse side effects, i did that when I bought the car.
K-Town Brick Militia______________94 854 The BBQ_________________97 Pewter T5 teh dd
I was us up all night with a rusty hammer trying to build a fence around these magic beans my dreams have gathered
Posted 24 March 2010 - 04:41 AM
rsmigel, on 22 March 2010 - 02:45 PM, said:
What are you doing?
Replacing the hose going from the oil separator to the fresh air tube specifically. I was confused because the hose I took off had the vacuum fitting on the fresh air tube, but there's no tube coming out the other side of the "padding" where the oil separator is.
On a side note, the sludge inside the PCV tube was revolting. I should have taken a picture
Posted 24 March 2010 - 12:13 PM
On my 1994 855T, the hose going from my Oil Separator to the PTC is a relatively large diameter hose with no other smaller vacuum hoses bundled with it. My replacement hose was more of an "assembly", with a small vacuum line running within the padding of the large diameter hose and extending about 6" from each end. I cut off the ends of this small diameter vacuum hose since my OEM hose didn't use them.
