I started to follow this procedure but felt it was unnecessary to do all it said.http://volvospeed.co...howtopic=111546
Once I got the old bushings off (I did both sides), I positioned the bushings on their respective flanges first. Then I positioned the arms where they should be.
Once the arms were in place I start each 18 bolt by feel. Each 18mm bolt head is accessible by way of the opposing arms access hole. They threaded fine. Then I torqued them down IN PLACE. Then I tightened the 21 mm nuts....done
No twisting arms or disconnecting brake lines, compressing springs etc, etc
Oh, and I didn't torque them to spec. but they are good and tight. no problems. no noises.
I don't know guys...seems to have worked fine.
Let me know what you think.
p.s. is there someone here who knows what the official Volvo procedure is on this job?
