Adapter To Hook Up Stock Amp To An Aftermarket Hu?
Posted 30 December 2004 - 10:22 PM
Anyways you just unplug the AMP cable from the back of the stock radio, plug in this adapter harness into the AMP plug, plug the RCAs into the back of your new aftermarket head unit, and enjoy your amplified sound.
The cost would probably end up being around $10.
Obviously you have to already have the stock Volvo amplifier to use this cable. And this isn't for the audiophiles out there as you guys would never think of using the stock amp. But for someone like me I'm fine with it and am making a cable for myself and may as well make a few more if anyone is interested.
- Slater
Posted 30 December 2004 - 10:38 PM
Posted 30 December 2004 - 11:54 PM
I will be importing them from England. Apparently they are VERY common over there because most european automakers use them for their audio. Like you I couldn't find a place in the US that would sell a small qty (i.e. 1-2).
There is a mod on AndrewRs 850 website, but it's the OPPOSITE of what I'm doing and he was only able to find an 8-pin DIN and had to cut off 2 of the pins and bend them to fit. Quite a hack. This will be professional and done correctly as I have an electrical background.
- Slater
Posted 31 December 2004 - 06:46 AM
Posted 31 December 2004 - 05:08 PM
I have no idea of the cost yet because the parts are cheaperas qty goes up, and shipping costs go down per piece as well. If 20 poeple were interested I'm sure it would be $10 shipped. But if only you and me are interested, then I'm sure it will be more.
I'm not looking to get rich, I just want one for myself. But I figured if I could help some people in the process than all the better.
- Slater
Posted 04 January 2005 - 06:52 AM
He is talking about hooking up a factory Volvo amp to a aftermarket HU. You are talking about hooking up an aftermarket amp to a factory HU.
1998 V70 T5
Chrome 19" Niche Rhine Wheels
Posted 04 January 2005 - 07:01 AM
#10 Guest_Guest_*
Posted 05 January 2005 - 12:08 AM
823 4th Street
San Rafael, CA 94901
415 457 - 0466
they carry the large 6-pin din
#11 Guest_Guest_*
Posted 05 January 2005 - 12:11 AM
http://www.electronicplus.com/content/Prod...=aco&subcat=ad1
#12 Guest_Guest_*
Posted 05 January 2005 - 12:12 AM
Posted 05 January 2005 - 02:59 AM
'95 T5-R. speedtuning. ipd. h&r / bilstein. ebc. kenwood. 14.2 @ 98mph
#14
Posted 05 January 2005 - 05:36 AM
#16
Posted 05 January 2005 - 08:31 PM
I would have to agree! Especially since I've had a Kenwood DDX7015 sitting around for four months now!!
jwm
1999 C70 HPT 5 speed, Upsolute ECU Upgrade, 19T Turbo, Supersprint Exhaust, 3" EST Downpipe, EST Intercooler, S60R Exhaust Manifold, Clear Corners and Euro Clear Headlights, BMC CDA Intake, OEM Strut Brace, XC70 Grille, IPD Sway Bars F/R, KW Variant 2 Coilovers, VMS sway bar links, Aluminum Dash OEM and EST Short Shifter, HRE 446Rs w/ Goodyear Eagle F1 GS-D3s Defi D-Gauge boost gauge, Innovate WBO2, HTS hoses, Samco stuff. - VMS Motor installed
1998 C70 HPT 5 speed saffron metallic, 61,000 miles, IPD Sway Bars F/R, KW Variant 2 Coilovers (***Not installed - Clear Corners and Euro Clear Headlights, OEM Strut Brace, XC70 Grille***)- ***SOLD***
2001 XC70 White - Wife driven
Past Volvos
1998 S70 T5, black - My first Volvo
1996 850
1998 C70 auto, white
2005 XC90 - Disappointing POS
#17
Posted 06 January 2005 - 05:08 AM
jwm
Wow interesting b/c thats what i want this piece for. Want to put the ddx7015 into my c70 as well. got the music keg right now hooked up with a fm modulator. cant wait to get 1 and throw it in.
#18
Posted 06 January 2005 - 05:24 AM
darn! I thought no one was interested because the thread just sat there for days. So I ordered my parts from GB (i.e. enough for just me).
Oh well. At least now I know I can get the female DIN in the US (thanks to whomever posted the link).
I talked to a Scosch tech today on something unrelated and mentioned what I was planning on doing. He claimed that it wouldn't work because the amp and radio share a common ground or someting about the ground that was wierd. But we'll see it it works grounding the radio and amp to the chassis. The audio cable is shielded and will be grounded to the connectors, so there should not be any ground loops or engine noise interference.
I'll keep everyone posted. Also, again I'm not out to make a million bucks - just enough to cover my time. I will post a how2 so the people that are electornically inclined can do it themselves, but I just figured I would make them for people that don't know how to or are too busy to do it themselves. I know if I could have bought a ready-to-go cable that already had all of the development testing and kinks worked out for only a few bucks more than I could make it myself for, I would have bought it in a heartbeat!
- Slater
Edited by Slater, 06 January 2005 - 05:25 AM.
#19
Posted 08 January 2005 - 11:17 PM
- Slater
OK, I made a cable and it worked perfectly. It took waaay longer tham I thought as the pins on the DIN plug are smaller than I imagined and it wasn't exactly easy to solder all of the pins. I did finish eventually though and tried it tonight.
It works great except that I am getting engine niose when the radio is off. I think I may have a ground loop. Can anyone help diagnose where the problem may be.
Here's the ground setup:
The DIN plug going from the amp had a 12v+ power and ground in addition to the audio channels. I just connected the amp ground to the radio ground (so they are sharing the same ground - the stock radio ground on the stock Volvo radio harness). Also, the RCA cables have a ground (the shielding) which I grounded to the DIN plug itself. So all 4 RCAs ground to the metal outside of the DIN plug itself. Which as you know plugs into the AMP connector from the amp.
So I have a feeling there's a ground loop because the RCA plugs plug into the DIN plug going to the AMP and also plugs into the head unit's RCA outputs. Then the AMP connector itself is grounded to the DIN plug which grounds itself to the factory amp where it plugs in. Then the official ground from the amp and radio are connected together at the same location.
Does that make sense?
I was thinking of keeping the radio and amp ground seperate and just grounding the amp to the chassis. Another option is an "RCA ground loop isolator" that you can get at any stereo place (Best Buy, Wal Mart, Circuit City, etc).
Any ideas?
- Slater
#20 Guest_Guest_mavnick_*_*
Posted 10 January 2005 - 03:00 AM
- Slater
Great Idea! Let me know when they are available.
