Does anyone know how much brake fluid is needed to flush the brakes on a stock '98 S70 T-5?
Also, has anyone had good/bad experience with the Motive Power Bleeder?
Thanks.
Brake Fluid Flush
Started by gatlin, Mar 21 2005 03:03 PM
7 replies to this topic
Posted 21 March 2005 - 03:03 PM
Gatlin
'98 S70 T5 - 223K miles
'04 XC90 T6 - 70K miles
Posted 21 March 2005 - 03:34 PM
QUOTE(gatlin @ Mar 21 2005, 09:03 AM)
Thanks.
Thanks.
Liter will get the job done. Just remove as much old fluid from the tank before you start.
Volvospeed On Google+
Posted 21 March 2005 - 06:47 PM
When I bought my brake fluid from the Volvo dealership it came in a bottle that said 800 ml on it. The techs there said that will be enough for a full flush, provided that you remove all of the old fluid from the reservior. Make sure it is DOT 4+.
Good Luck
Oh and if you are removing the fluid by the use of a vacuum pump from the bleeding nipples on the caliper. Put some grease or vasoline around the threads of the nipple before you flush. If you don't you'll see small air bubbles in the line and this confused me at first, I thought that there was perpetual air in the lines.
Good Luck
Posted 21 March 2005 - 07:32 PM
I have nothing but good things to say about the Motive Products Bleeder. Easiest bleed I've ever done.
DEWFPO
DEWFPO
Posted 22 March 2005 - 08:07 PM
I used the ATE blue brake fluid for the first time and didn't waste much...you can really see when you have the new fluid with the color change. 1 litre was enough to change the fluid in both my 850 and my Tundra. Next time I'll use ATE amber fluid...same stuff without the blue dye.
DOT 4+ and DOT5.1 are the same stuff, just different notation from different makers. DOT5 is the do-not-use silicone fluid, of course.
Ken
Ken
Posted 23 March 2005 - 06:27 PM
QUOTE(KLS @ Mar 22 2005, 04:07 PM)
Ken
Ken
What is DOT 4+? Does that mean that the 'exceeds DOT 3 and 4' fluids are not to be used? Should I just go with a NON-SILICONE DOT 5?
Thanks!
former owner of a 2000 S70 NA
How could you guys let me sell it?!
Posted 23 March 2005 - 07:17 PM
Non silicon DOT5 = DOT 5.1 = DOT 4+
- Sean
Posted 23 March 2005 - 11:25 PM
Do Not Use Dot5 in your car, the seals will not like it.
The system was made to have dot 4+ or dot5.1 in the car. You could put 3 or 4 in if you want but your boiling point of the fluid will be lowered.
