Sometimes I have a severe shake when I brake. I don't think this is a warped rotor because at low speed it doesn't do this. It is particurarly bad at high speed and low brake pressure when going down a long grade. My car is a '98 V70 T5. IPD suggested replacing the conrtol arm bushings, which I did and it seemed to help for a while, but then it came back worse. Any ideas?
Car Shakes During Braking
Started by mrb901, Mar 21 2005 08:41 PM
8 replies to this topic
Posted 21 March 2005 - 08:41 PM
Posted 21 March 2005 - 08:53 PM
warped front rotors. have had same symptoms.
2007 V70R
Posted 22 March 2005 - 12:10 AM
QUOTE(mrb901 @ Mar 21 2005, 04:41 PM)
Is the shaking more in the steering wheel, brake pedal, or general car shake?
Steering wheel=front rotors, brake pedal=rear rotors, entire car=really bad fronts or rears (REALLY BAD) or, more likely, control arm bushings.
Jens Christensen
Posted 22 March 2005 - 01:08 AM
It's in the steering wheel. I've looked at the rotors and they don't look warped. I've already replaced the bushings because I had the rotors turned not too long ago. Thanks for your help.
Posted 22 March 2005 - 01:12 AM
If your steering wheel shakes with brake application, your front rotors are more than likely warped.
Posted 22 March 2005 - 01:40 AM
If you turned the rotors recently, I would ask if you have OEM pads on there. If not, I strongly recommend you return to them. I have had problems with warped rotors, and I firmly believe it was due to aftermarket pads.
2007 V70R
Posted 22 March 2005 - 02:25 AM
QUOTE(mrb901 @ Mar 21 2005, 09:08 PM)
Rotors wouldn't look warped...maybe grooved, but you wouldn't see warpage without a straight edge.
Jens Christensen
Posted 22 March 2005 - 08:00 PM
Also consider sticking sliding pins on the front calipers. Those can cause heavy vibrations at some times and not at others.
Ken
Ken
