When I am at idle, approx. every 15 seconds, I hear a click from the engine, accompanied by a drop in engine speed (by about 100 RPM)-- and then it comes right back up to normal very quickly.
Is this something to be concerned about? Is it normal?
Thanks!
Idle Issue?
Started by hotch, Mar 23 2005 07:43 PM
6 replies to this topic
Posted 23 March 2005 - 07:43 PM
1997 Volvo 850R
Side Markers - Rebadged - Seafoamed - Moose Added - Homelink Visor - Powerbook G4
Volans / Pirelli P-Zero Nero M+S (215/45/17) / Stock Suspension (Koni + Eibach soon)
Posted 23 March 2005 - 08:08 PM
do you have your A/C turned on? if you have your Defrost turned on, your A/C is on then too.
'06 Mazda3
Posted 23 March 2005 - 08:20 PM
QUOTE(felix88 @ Mar 23 2005, 02:08 PM)
hmm, i will check. it's pretty cold here...
1997 Volvo 850R
Posted 23 March 2005 - 08:25 PM
Idle Air Control motor either needs cleaning or replaced. You should also try cleaning the throttle body.
- Scott
'05 S60 T5
'04 S80 2.5T
'05 S60 T5
'04 S80 2.5T
Posted 23 March 2005 - 11:23 PM
The clicking noise sounds like it could be your A/C compressor kicking in. Make sure you don't have Defrost selected and the a/c is off and see if the noise is still there. Look down at the compressor when the noise happens and see if thats it.
Posted 23 March 2005 - 11:54 PM
QUOTE(Bay13 Admin @ Mar 23 2005, 06:23 PM)
That's what it sounds like to me
"SMOKE TROUT NOT CRACK"
Posted 24 March 2005 - 03:56 AM
I have a simalar Idle Noise problem....my engine area has a rattle noise..followed by clicks at random itervals. Although my RPM doesn't dip like yours. I think mine could be an A/C problem as well, because our aircon currently has 7 error faults and something could be causing that noise. We're going to see if we can get it fixed soon though. I hope it's coming from the A/C rather then something else in the engine bay.
Anyway...i think you should get yours checked out as well.
1993 Volvo 850 GLE - Stock No Mods
