Monkeying Pcv System!
17 replies to this topic
#1 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 24 March 2005 - 12:32 AM
Alright, I had the classic smoke coming out of the dipstick thing going on for a little while. It was a good amount of smoke too, not just a lil. Over the past coupla days, I've had time to tear into it and see what's goin' on. Alright so here's what I did:
- Replaced oil seperator with a new one from the dealer. The old one wasn't really "clogged".
- Completely removed ALL PCV lines and cleaned out the smaller lines with pipe cleaner and completely sprayed out the bigger lines w/ a high pressure washer thing. All the parts dried over night. I verified that none of the lines had ANY blockage whatsoever.
- I re-installed everything today exactly as it was using VADIS as a guide as well.
So, I started the car up, let it get up to operating temperature and.... still smoke coming out of the dipstick tube and oil filler cap. I know 100% that there is NO blockage in the PCV system. Can anyone explain why this is still happening?
- Sean
#2 Bay13
Bay13
  • 6,378 posts
Posted 24 March 2005 - 12:34 AM
How about the intake pipe that connects to the turbo, where two of the hoses attach, one big from the PCV box and the smaller one for vacuum. Anyway that hose needs replacing sometimes cause it gets all clogged up.
#3 merlin390
merlin390
  • 2,778 posts
Posted 24 March 2005 - 12:41 AM
Rich, I did the same thing and I have the same results, mine is a NA though
#4 Bay13
Bay13
  • 6,378 posts
Posted 24 March 2005 - 12:45 AM
On the NA, make sure the vacuum line is clear to help suck the fumes in.
#5 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 24 March 2005 - 12:48 AM
QUOTE(Bay13 Admin @ Mar 23 2005, 06:34 PM)
I totally cleaned that one out too with the pipe cleaner and blew through it afterwards to verify that it was clear.
- Sean
#6 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 24 March 2005 - 01:02 AM
I figured these turbo cars didn't have a PCV system since I couldn't see it easily. Where the heck is it? Is it something I should look at as part of stage 0?
#7 merlin390
merlin390
  • 2,778 posts
Posted 24 March 2005 - 01:07 AM
I replaced the vacuum line with a new silicone hose.
#8 hoyt
hoyt
  • 130 posts
Posted 24 March 2005 - 01:15 AM
Stupid question, but what is being harmed in the engine when your PCV system isn't working properly? I remember my dipstick tube and oil cap smoking as much as 5 years ago...
Thanks,
--hoyt
1995 850, 209k and still ticking | 2001 SAAB 9-3 Viggen
#9 merlin390
merlin390
  • 2,778 posts
Posted 24 March 2005 - 01:30 AM
added crank case pressure pushing seals out and thus leaking. Namely the RMS
#10 Guest_AlvinL_*
Guest_AlvinL_*
Posted 24 March 2005 - 04:17 AM
Did you check lower connection from the separator to the block? I found carbon in mine (restriction) that had to be slowly cleaned out...
#11 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 24 March 2005 - 05:41 AM
wow...that sucks alot...after a thorough cleaning like that?....does the smoke thing have any connection to the Evap canister or the lines to the evap sensor/system?....maybe that has something to do with it?
How long did it take you to pull everything apart and back together, and what is a part number for that oil separator???
Also, did you REPLACE anything else man?
There has to be another clog somewhere, or maybe some gas or condensation in the oil?....did you change the oil after the cleaning?
#12 merlin390
merlin390
  • 2,778 posts
Posted 24 March 2005 - 06:22 AM
i am going to pull it all apart again I used round wire brushes to clean out the ports and A LOT of carb spray.
#13 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 24 March 2005 - 01:14 PM
QUOTE(prasamin @ Mar 23 2005, 11:41 PM)
There was hardly any build-up even in the oil box or where it connects in to the block. I know the guy that owned the car before me and it was meticulously maintained. Taking everything apart took no more than 2 hours. Getting it all back together took about twice as long. It doesn't have anything to do with the EVAP system. A few tips for anyone doing the job:
1. EGR makes this job a helluva lot more difficult than it would otherwise be. Make sure you remove the hard to get to 8mm bolt first.
2. When re-installing the pipe that goes from the top of the oil box to where it goes into the head, you have to install it simultaneously with the intake manifold. Otherwise, you'll sit there wondering why the bloody thing won't go back into its bloody spot. Maybe this is due to my lack of sleep before doing the job though huh.gif .
3. Be VERY careful with the long plastic lines in the PCV system. They are brittle and break quite easily due to all of the heat over the years.
I am going to clean all of the lines again including the one that Rich originally suggested. I will report any progress rolleyes.gif .
- Sean
#14 Joe_m
Joe_m
  • 83 posts
Posted 24 March 2005 - 01:59 PM
So would it be safe to wait for smoke from the dipstick before attending to the PCV system on my NA? I have a bunch of stuff in line before tending to it (trans flush, coolant/thermostat, oil change, cabin and air filter change, brake fluid flush, life).
former owner of a 2000 S70 NA
How could you guys let me sell it?!
#15 orange850t
orange850t
  • 868 posts
Posted 24 March 2005 - 08:59 PM
Ok i have read all of the PCV threads and i have a couple of solid questions which I think haven't been asked yet (hard to believe.)
1. What is the part number of a replacement induction hose for the 850 turbo and does it include the junction block??
2. If we were to replace the induction hose with say a stainless pipe, 10mm barb on the intake pipe and then plumb a closed catch between it and the oil separator box, would this do the trick?
Just thinking out loud.
95 855T Autumn Gold
#16 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 25 March 2005 - 05:29 PM
Oh monkey! I just figured it out! OK, the vacuum line that runs from the intake manifold over to the air intake pipe got melted closed somehow. blink.gif It has been rigged with some 4 mm silicon hose and I no longer have smoke from the dipstick tube biggrin.gif . I did all that work for nothing. Silly me dry.gif .
- Sean
#17 merlin390
merlin390
  • 2,778 posts
Posted 25 March 2005 - 06:24 PM
Ichecked that too. mine was good. I pulled the spark plug cover off this morning and that hose and it was clean, no build up NOTHING. I am going to pull the intake Sunday probably and replace the factory catch can and double check all the passages for blockage. If tihs doesnt cure it then I am just going to hook a 12v electric vacuum pump to it and let it ride. 15" of vac in the crackcase at all times can't hurt
Edited by merlin390, 25 March 2005 - 06:29 PM.
#18 Guest_AlvinL_*
Guest_AlvinL_*
Posted 25 March 2005 - 07:58 PM
QUOTE(Joe_m @ Mar 24 2005, 01:59 PM)
No smoke- 100% PCV efficiency. You should include in your schedule mntc to check/clean the PCV. Like check/wipe/clean all the piping you can get to and check the vacuum line. There's only so much you can do, maintenance wise, to maintain it at 100%. Eventually, even if all the parts you can get to is clean, the other areas gets plugged or the PCV system is unable ventilate a worned engine?
P.S. N/A engines needs regular wiping of the throttle body to keep it clean because evntually you'll notice the pedal start to stick. That's why the throttle body cleaning. Turbo don't have that much of a problem. All the oil in the fumes gets separated in the intercooler... dry.gif
Just my 2 cents...
