I have 2 leaks that I can tell of, one if the turbo return line, I went to fix this and one of the allen hex bolts is already stripped out, so I need to somehow get that off, but thats another issue.
When I was under there I noticed that theres also oil leaking from around the turbo area, is there anything easy to fix there? Also I think the turbo air(?) hose that goes into it is shot as its soft and wet.
Any ideas? About a quart every 2 days, but I lose a lot of oil if I spool the turbo up, at that point I can actually smell it when I drive, thanks!
PS- I did have the entire PCV system cleaned a month ago so thats all set.
-John
Oil Leaking From Turbo?
Started by Johnshan, Mar 24 2005 01:34 AM
7 replies to this topic
Posted 24 March 2005 - 01:34 AM
Posted 24 March 2005 - 02:06 AM
You're most likely losing it out the return line.
That's right bitches. I'm back.
Posted 24 March 2005 - 02:12 AM
You should talk to Bay13, he knows his stuff
GAYTARD
#4 Guest_Guest_John_*_*
Posted 24 March 2005 - 02:28 AM
QUOTE(fast_box @ Mar 24 2005, 02:12 AM)
Thanks for the replys, the oil is up around the turbo though, the oil return line is on the back of the block (at least the one im talking about).
Unless theres also a return line on the turbo itself?
Thanks for any help.
-John
Posted 24 March 2005 - 03:12 AM
Try tightening the clamp on the inlet hose to the turbo, the clamp is on the turbo, that will stop some of the oil seepage from the turbo.
Posted 24 March 2005 - 09:46 PM
QUOTE(Bay13 Admin @ Mar 24 2005, 03:12 AM)
Why would the air inlet hose on the turbo be leaking oil? My car uses a bit of oil so I'm wondering.
-Michael S
'95 850 turbo
chip, exh, down pipe, K&N drop in
'95 850 Turbo
PES, SCT, and Upsolute chips
3" Ferrita down pipe w/ race cat
2.5" Ferrita cat back
4" crome tip
K&N drop in filter
A-pillar boost gauge
ipd sway bars
Bilstein HD
134db air horn
Euro convex drivers mirror
4" crome tip
K&N drop in filter
ipd sway bars
Bilstein HD
134db air horn
Posted 24 March 2005 - 09:48 PM
Where there is an oil outlet there has got to be an ...
wait for it
oil inlet
wait for it
oil inlet
95 855T Autumn Gold
Posted 25 March 2005 - 01:00 AM
look at the hose that attaches to the turbo, the plastic hose, then about 1 1/2 inches up the pipe is a huge, maybe not huge, but large the size of your thumb hose that connects there and sucks in the crank case fumes (read, oil mist). Thats why you have or could have a slight oil leak there.
This topic is locked
