Strong Fuel/exhaust Smell
7 replies to this topic
#1 Guest_Guest_cking1975_*
Posted 08 April 2004 - 12:08 PM
I am trying to figure out why my car smells like it is running really rich. I have a 94 850 turbo with 148,00 miles on it. I just spent three months fixing all kinds of problems and the car was running great. Then I had the car shipped from CA to RI and when it got here the check engine light came on and the fuel smell became really strong. today I am going to check all the hoses and I just replaced the fuel filter before I left and it does not have a leak. I am thinking that a hose may have come off or maybe something is clogged from the car sitting for 2 weeks. I need some help, please do not ask me to have the car scanned for 80 dollars, this has always been a waste of money.
Corey
#2 Chopper
Chopper
  • 824 posts
Posted 08 April 2004 - 02:02 PM
Do you smell this in the cabin, or are you talking about how it smells coming out o the tailpipe?
If you smell it in the cabin, turn the key to position II without turning the car out, you'll hear the fuel system pressurized. Now inspect it carefully (especially lines to fuel rail/fuel pressure regulator, and around the fuel rail at the injectors). Since the fuel is prressurized you should see any that is coming out of the system.
1998 V70 T5 / 2000 BMW 328i 5spd
#3 Guest_Guest_*
Guest_Guest_*
Posted 08 April 2004 - 11:30 PM
Thanks I will do that
#4 patrick
patrick
  • 2,656 posts
Posted 09 April 2004 - 12:22 AM
check your 02 sensors and Cat also, to me at least(bad smeller) the sulfer<dead catalyst> smell and the burning rich smell are soemwhat similar in the cabin.
Current: 2001 Grand Cherokee Limited V8 4x4 2.5in lift and some other goodies
Past:
94 850 160k sold
84 242ti 202k sold
99 F150 4x4 99k sold
#5 Chopper
Chopper
  • 824 posts
Posted 09 April 2004 - 01:24 PM
Another thought,
If you smell things sitting in traffic it could be coming from any part of the engine/exhaust system (like the previously mentioned catayltic converter). If you only smell it at highway speeds, it is probably coming from the engine compartment.
#6 Guest_Guest_Brickbat_*
Posted 09 April 2004 - 04:56 PM
QUOTE(Guest_cking1975 @ Apr 8 2004, 12:08 PM)
I think you should be able te read the codes yourself in a 94. They might be helpful - if there's one thing the OBD codes pick up it's mixture-related problems. The OBD system was put there by EPA mandate in the first place.
#7 Pauloil
Pauloil
  • 506 posts
Posted 09 April 2004 - 10:18 PM
my 95 850 was smelling and running poorly when cold, and it turned out to be the MAF sensor. figure that
1995 850 glt rattling down the road at 157K
99 V70XC 120K
#8 Guest_Marv Helon_*
Guest_Marv Helon_*
Posted 07 May 2004 - 09:56 PM
Have exhaust smell in cabin. Dealer says no leaks in exhaust system. Any ideas.
