Installed Bsr Stage 3 Chip Tonight. Holy Moly!
Posted 13 May 2005 - 04:03 AM
Anyways, at WOT my stock needle goes right to the end of the white and stays right there all the way to redline. It's my understanding that the end of the white is 15psi. Is that correct?
The BSR Stage 3 is supposed to be 18psi which is why I'm wondering.
No, I don't have my Defi boost gauge hooked up yet. I know the stock gauge is crap but only because it's slow to repsond.
- Slater
Posted 13 May 2005 - 04:08 AM
life starts at et0
Posted 13 May 2005 - 04:16 AM
Aw cmon now cut me some slack. I already did Stage 0.
If you had a BSR chip and you were sitting there staring at it, I doubt anyone could resist popping it in for a little test drive. We're not talking a 19T upgrade or something. It's just a chip not an MBC. I doubt 75% of the people that got in on the ST group buy have a boost gauge.
I'll get the gauge in. I was waiting to figure out how I was going to mount it first...
- Slater
Posted 13 May 2005 - 04:30 AM
You probably need to get a MBC to set it up that high. Jae got a ST 17psi chip and it only builds 15psi.
Good luck.
Posted 13 May 2005 - 04:33 AM
Good luck.
18psi is what BSR claims.
So it's the 15G wg actuator holding me back? Or the stock BCS?
Posted 13 May 2005 - 04:50 AM
Posted 13 May 2005 - 05:19 AM
it's the BCS...you can go "whatever" PSI on the 15, but of course you'll risk kaboom....my 17psi spikes about 17 and usually sets at about 14 usually....i need my downpipe and catback to really be able to go crazy and test the psi
Posted 13 May 2005 - 05:45 AM
Past: '05 S60R // '98 C70 T5M // '95 BMW M3 // '94 855
Posted 13 May 2005 - 12:42 PM
I'll know when I go to the dyno. I'm going to do a shootout with the stock T-5R ECU, BSR, Upsolute, and ST.
Should be interesting...
Posted 13 May 2005 - 01:21 PM
Volvo 850R Auto, 162K, Bobcat\SW Autos Custom Ecu, 18T, Reverse IC, 13 Row (Mocal Type) Engine Oil Cooler, 39 Row (3x 13 Row's)(Mocal Type) ATF Cooler, 20psi VDO Boost Gauge, Osram 50% Silverstars upfront, ITG Filter, OEM Strutbrace, Aerial Down Switch, 302mm Front Discs, Ferodo DS2500 Pads Front & Rear, Goodridge SS Brake Hoses, New Brake Hard Pipes, ATE Super Blue Brake Fluid, Koni Ajustables, Eibach pro kit, Slaters Link Rods, 4x Nankang NS-2 215/45/17 XL, Clear Side Repeaters, 70 Series Washer Jets, Powerflex Control Arm Bushes.
Fully Synthetic 5w-40 every 5K Miles, and flushed with 10l of Comma Dexron 3 ATF every other oil change.
In Progress: Custom Alu IC with 2.5" Core IC (Same Dimension as Stock one, Just thicker)
To Come: 3" Mandrel Bent down pipe and Cat Back.
Posted 13 May 2005 - 01:30 PM
Hmmm...that will be interesting....the final word on a much discussed topic....I look forward to it!
9
1999 V70 wifes
1992 745 Turbo
2003 Z1000
2005 SV650- #11 SuperSport
2002 SV700 (100RWHP @ 330 LBS) #11 Superbike
02 TTR125L-Parking Lot Assaulter
93 DR- Motard
Dunwoody, GA
#12 Guest_DougK_*
Posted 13 May 2005 - 01:44 PM
Posted 13 May 2005 - 02:08 PM
12-14? 12 sounds awefully low. The stock T-5R runs almost 11psi, which is 3/4ths of the way on my gauge. Now with the BSR it's at the end, which can't be 12. I
ll buy 14 or 15.
I just need to hook up the Defi and see what the heck is going on.
- Slater
#14
Posted 13 May 2005 - 02:23 PM
- Slater
Your boost will increase by a few pounds once you install the remaining Stage 3 components (downpipe exhaust). That's why you are not seeing the expected boost figures. Good luck!
#15
Posted 13 May 2005 - 02:29 PM
That's what I was thinking.
#16
Posted 13 May 2005 - 02:34 PM
Someone brave enough to venture out and do something
SpeedTuning 17PSI - MSD 6A - 3" Back - Sunglasses
#17
Posted 13 May 2005 - 02:36 PM
what chip are you on? I seem to recall SpeedTuning...right?
#18
Posted 13 May 2005 - 06:55 PM
I was also told that it should be 18psi. But with the stock conical 15g, whats the point of 18psi anyway? Isn't that well outside the range of efficiency?
The only thing I have left to add would be my Atech I/C. I know that will help some, but not *that* much.
my Defi gauges have been waiting patiently for me to install them. I've been putting other stuff in front like trans cooler, axles, hubs and brakes. Soon though...
#19
Posted 13 May 2005 - 09:45 PM
SOLD 1996 Volvo 850 TurBSR
1967 Sunbeam Alpine 1767cc 100octane
2005 Subaru OBXT Ltd
(former) Vendor for Front & AWD drive Performance Parts
