My drivers side headlight lens is broken. Somebody hit it while in the store. But anyways i bought a new bulb and it worked for about 2 weeks then blew. So i bought another thinking something must of hit it and that one blew in 2 hours. Do you think this is because of air getting into the headlight or something? Do you think a new lens or assembly will fix this.
Also my service engine light is on. Not the check engine light but the other one. Is there a way to get rid of this or is it something only the dealer can make go away. I did a full tune-up on the car. Except for cap and rotor.
by the way this is a 95 850 turbo. Auto.
Keep Blowing Headlight Bulbs
Started by
Guest_Andrew Shott_*
, Jun 02 2005 12:21 AM
5 replies to this topic
#1 Guest_Andrew Shott_*
Posted 02 June 2005 - 12:21 AM
Posted 02 June 2005 - 12:26 AM
Not sure about your bulb problem but this is how to clear your service light http://volvospeed.com/850slight.php
96 855R 158k miles
Posted 02 June 2005 - 12:46 AM
Headlight bulbs are very sensitive and even a small piece of dirt or oil can cause them to develop hotspots and fail. It sounds as if that's the problem. A new lens should fix it.
EDIT: Also, when installing headlight bulbs, be very careful not to touch the glass part.
Edited by White850T5, 02 June 2005 - 12:47 AM.
- Sean
Posted 02 June 2005 - 01:42 AM
I have a spare lense for sale ? will include a headlight buld & sidemarkere wiring harness for free.
2000 Mercedes W210
1995 854 NA Auto
RIP - Dad - M.G.T 10/31/42 - 12/03/05 "Press On"
1995 854 NA Auto
Posted 02 June 2005 - 02:45 AM
Don't touch the glass part of the bulb. If you do, clean it off with rubbing alcohol and clean towel.
1998 Volvo V70 R
Posted 02 June 2005 - 04:38 AM
heh, i do stage lighting as a side job and one thing you learn real fast is to handle the lamps with either gloves on, or a paper towel or something
1995 855 Turbo - 190k Miles
