Delta Link Camber Bolt
#1 lcc014
lcc014
  • 735 posts
Posted 02 June 2005 - 01:48 AM
Hi,
One of the camber adjustment bolts of the passenger side delta link arm was snapped off. I tried to removed the remaining bolt but no luck. It was stucked and room in that area was so tight. mad.gif
How can I remove it so that I can install a new one ? I bought the new bolt and nut from dealer but could not install it sad.gif
Thannks,
Ching-Ho Cheng
1995 855 NA: Bilstien Touring Strut & Shocks, Volvo Protective Grill, K&N Filter, E-Code Lens, ClearCorner Light, Alpine CD-Changer, AutoDim RearView Mirror, 6000K HID, Tranny Cooler
2005 530i: PPP, CWP, Nav, Xeon, Rear SunShade, Steptronics, Blue Light Door Sills, Wide Angle Driver Side Mirror, M5 iDrive Knob, White LED License Plate Light
#2 Guest_Guest_*
Guest_Guest_*
Posted 02 June 2005 - 05:48 PM
camber should be static on the delta link... unsure.gif ..i think..
#3 lcc014
lcc014
  • 735 posts
Posted 02 June 2005 - 05:53 PM
QUOTE(Guest @ Jun 2 2005, 01:48 PM)
Yes, but I need to removed the broken bolt and put on a new bolt and nut to hold the link in place such that the camber would not be altered from the vibration of the suspension.
Delta link comes in 2 bolts/nuts at each end to hold down the link at certain camber angle. Mine is missing (broken off) one nut at the passenger side end. Need suggestion/advice to remove the stucked old bolt.
Ching-Ho Cheng
