Post Your 60 Ft Times!
88 replies to this topic
#1 850 GLT
850 GLT
  • 300 posts
Posted 26 August 2004 - 12:40 AM
I'm curious as to what the best 60 ft time would be for our cars on street tires. If you have a manual tranny make sure you mention that. Also, explain what kind of tires, pressures, and technique you used if possible.
After 3 runs my best was a 2.306. I'm running 215/45/17 Goodyear GS-D3's. Judging from the video my friend took of one of my runs I'm getting a very small amount of tire spin. I brake torqued up to 2500ish and then floored it. I was running normal tire pressure, ~35 psi.
Alex
60ft Times:
1.95 ROB @ VMS C70 auto
1.957 BOOSTEDS60R
1.968 Volvospeed Admin
2.09 '95R
2.12 StickThatClutch S70 T5
2.130 Turbor850 S60R manual
2.157 UberV70 v70 awd manual
2.164 xcaliber912
2.175 JHEIII850Turbo 850 T5
2.183 Odell (his black 850)
2.197 Jesse850GLT (lpt)
2.206 ginkof S70 T5
2.208 850R//3KILLER 850r
2.234 ToxicLemonade 850 t5r
2.240 The Wifes Car s70
2.260 andrewclee 850r
2.270 Turbo Brick
2.271 850 glt
2.283 swdracr 850r
2.318 Melted
2.375 deafdano 850
2.428 Martin s70 t5 manual
2.445 Johann 850 manual
2.452 HPTJoe c70
2.495 Odell (bills old 850) manual
2.6XX Doug's Fabulous Launch
Ignorance is bliss.
user posted image
#2 J0E
J0E
  • 2,025 posts
Posted 26 August 2004 - 03:17 AM
2.452, and not an ounce of wheelspin.
#3 odell1523
odell1523
  • 1,293 posts
Posted 26 August 2004 - 03:46 AM
2.495 is best on the new volvo and crazing spinning and 2.183 in my black car with just chip, intake and stock wheels...stock w heels work so much better than 18s
"Silver 850 t-5"
m56h swap, r clutch, 19t turbo
custom tuned ECU set at 19psi
optiflow intake,turboxs rfl bov w/ block off plate
reverse IC,aquamist 2d, 3" turboback(catless)
magnaflow stainless muffler
17" TSW eurace and 18" voxx forza(FOR SALE), H&R lowering springs
Bilstein yellow struts and shocks
Volvo Strut tower brace, carbon fiber cam cover
Sparco Milano racing seat
yet to install: FMIC KIT!
#4 Johann
  • 4,981 posts
Posted 26 August 2004 - 06:41 AM
2.445 is the best I did so far..
#5 deafdano
deafdano
  • 104 posts
Posted 26 August 2004 - 12:02 PM
2.375 60' Manual transmission. Running 215 40 17 Toyo T1's.
98 S70 T5M - K&N - Speedtuning ECU - 3" TME Downpipe - 2 1/2" CatBack
IPD Springs - Bilstein Shocks - IPD Anti Sway Bar - 14.004@102mph - 310,000 Miles
#6 odell1523
odell1523
  • 1,293 posts
Posted 26 August 2004 - 03:26 PM
i feel good knowing that someone else (johann) with a well modded car still gets bad 60's like me...what wheels/tires you running johann?
"Silver 850 t-5"
#7 UberV70
UberV70
    do the evolution
  • 2,215 posts
Posted 26 August 2004 - 05:18 PM
2.157 60'
Pirelli P-7000 215/35/19 34 PSI
V70 AWD 5-Speed Manual
I could probably do alot better but last time i went to the track (with new ecu) it was kinda cold and the track was slippery as hell. I think i could get a 2.0 on a hot day.
*edit* Just a note that this 60 foot time is BEFORE i got my new ECU *edit*
Edited by UberV70, 26 August 2004 - 07:14 PM.
My name is Adam and this is My Old and Un-Updated Cardomain Page
#8 ToxicLemonade
ToxicLemonade
  • 2,595 posts
Posted 26 August 2004 - 05:59 PM
2.234 on 17 inch with khumo supra 215's
Yellow 5 speed T5-R
#9 Johann
  • 4,981 posts
Posted 26 August 2004 - 07:11 PM
QUOTE(odell1523 @ Aug 26 2004, 09:26 AM)
Bridgestone Potenza S03 225/35-18 using several pressure settings.
#10 andrewclee
andrewclee
  • 202 posts
Posted 26 August 2004 - 07:45 PM
2.260 seconds
Yokohama Parada Spec-II
215-40-17
Brake torque at about 2500 rpms.
Andrew Lee
Sold in 2008, 1996 White 850R Wagon
#11 850R//3KILLER
850R//3KILLER
  • 9 posts
Posted 27 August 2004 - 06:12 AM
2.208 60ft in my 850R
how bout 60's from non volvo?
my old car, 92 talon awd 1.790!
bandimere speedway 5800ft asl
you guys not getting wheel spin need to put your foot in it a little more at the tree! biggrin.gif A bit of wheel spin is actually a good thing because it takes some of the load off your drivetrain and axles, as well the car fails to realize that the wheel is slipping (tracs-disengaged) and continues to increase rpm and boost pressure.
some of my highest traps and best 60's came from hard launching.
1 thing that should be noted here. A tenth less 60ft can turn into 2 tenths at the 1320 mark and
increased trap speeds!
Edited by 850R//3KILLER, 27 August 2004 - 06:33 AM.
#12 JESSEXC
JESSEXC
    Voice of Reason's Son
  • 3,249 posts
Posted 30 August 2004 - 02:10 AM
Found a better 60' Done with 13g turbo @ 13 psi and very little wheel spin
Edited by jesse850GLT, 30 August 2004 - 02:16 AM.
2002 XC Ocean Race # 377 of 650 Mods: Volvo rear center seat cooler,Back up Camera
#13 Turbo Brick
Turbo Brick
  • 488 posts
Posted 30 August 2004 - 05:21 PM
2.270 on the stock 16" wheels.. can't remember what kind of tire it was though.
QUOTE(850R//3KILLER @ Aug 27 2004, 02:12 AM)
1989 Mustang, stock suspension with aftermarket upper and lower control arms, ET streets and skinnies: 1.677 60', Bradenton Motorsports Park.
A note about the Volvo.. my car only picked up ~19mph in the last 1/8th mile on its best run so far. It's a shame how weak these cars are up top.
Edited by Turbo Brick, 30 August 2004 - 05:28 PM.
#14 swdracr
swdracr
    Pretty Boy Racing
  • 1,225 posts
Posted 30 August 2004 - 05:29 PM
2.283
205/45/17 Pirelli P Zeros ~35 psi
Edited by swdracr, 30 August 2004 - 05:29 PM.
Patrick
'97 850 RIPB Image
IPB Image
#15 The Wife's Car
The Wife's Car
  • 3 posts
Posted 31 August 2004 - 02:00 AM
2.240 60-foot on the stock S70 GLT wheels & tires, on a prepped track during a club event.
#16 The Wife's Car
The Wife's Car
  • 3 posts
Posted 31 August 2004 - 02:08 AM
QUOTE(850R//3KILLER @ Aug 27 2004, 12:12 AM)
1.771 in my 2001 Camaro SS (Heads/Cam/Headers/3500 stall/ET Streets)
#17 Guest_DougK_*
Guest_DougK_*
Posted 31 August 2004 - 03:49 AM
2.6 :*(
#18 850R//3KILLER
850R//3KILLER
  • 9 posts
Posted 31 August 2004 - 05:53 AM
QUOTE(The Wife's Car @ Aug 30 2004, 07:08 PM)
how fast is the SS?
thats a nice launch car must have some serious balls
#19 The Wife's Car
The Wife's Car
  • 3 posts
Posted 31 August 2004 - 01:00 PM
Thanks! I've run a best of 12.1 in the quarter mile, but that was with a completely worn out posi earlier this year. (Could only do a 1-tire burnout! blink.gif ) So with the new posi I had installed last month, it should run a 12.0 or 11.9, naturally aspirated.
I'd still like to see what the S70 GLT would run in the quarter, but my wife says no. Oh well. rolleyes.gif
#20 turbor850
turbor850
    i am the new pegs
  • 4,188 posts
Posted 31 August 2004 - 03:27 PM
2.130 - S60R 17'' Pegs
but missed second (doh !) and could have gotten 14.0, but left the day with
14.2 . . . . .
FIRST TO PUT 20G ON AN 850R
