O2 Sensor Questions
24 replies to this topic
#1 sweeedespeed
  • 393 posts
  • Interests:Sports, lifting, cars, VOLVOS
Posted 19 February 2008 - 02:51 AM
I have a bad o2 sensor. I ordered the rear one, but I think it may be the front sensor. Is there any way I could use a rear sensor on the front?
97 854 T5- Speedtuning Tune, OBX Turboback, Enkeis, QBM Spacer, Samco's,
IPD Short Ram, IPD Polys, HID's, Debadged, What horns?
Making grocery getting fun!
#2 lookforjoe
  • 7,810 posts
  • Interests:Making Stuff
Posted 19 February 2008 - 02:59 AM
QUOTE (760S @ Feb 18 2008, 09:51 PM) <{POST_SNAPBACK}>
Isn't the only difference the length of the harness? The signal is all the same - if it has the same # of wires & the same connector there should be no reason why not.
1998 V70 XR M66 10cm2Hotside/Garrett 60-1 Built T5 Motor '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DP back Dual Magnaflow 14834's May 2011 355WHP(@6400rpm) 347WTq(@4400rpm)@22psi Now with LGSpeed Header & Custom Intake Manifold! BIG 31x12x3"FMIC Currently sporting a vented piston!!!
#3 please delete
  • 5,799 posts
Posted 19 February 2008 - 04:10 AM
QUOTE (lookforjoe @ Feb 18 2008, 09:59 PM) <{POST_SNAPBACK}>
+1... its most likely the front one
#4 sweeedespeed
  • 393 posts
Posted 19 February 2008 - 04:20 AM
I had a code thrown dealing with the o2 sensor. According to the info computer, I am only getting 17MPG, but I went around 110 miles on about 4 gallons of gas. Also, the car runs fine without boost, but is not the same with it- it's sluggish and almost bogs. Would those be o2 sensor problems or maybe a MAF?
#5 garbergtsi
  • 411 posts
Posted 19 February 2008 - 01:10 PM
sounds like a boost leak to me...
#6 sweeedespeed
  • 393 posts
Posted 19 February 2008 - 01:35 PM
but would that be related to the CEL?
#7 7 VII 7
  • 22,324 posts
Posted 19 February 2008 - 01:45 PM
what was the CEL code?
1 of 1 - '97 427 854R - 105k
#8 please delete
  • 5,799 posts
Posted 19 February 2008 - 04:18 PM
QUOTE (760S @ Feb 19 2008, 08:35 AM) <{POST_SNAPBACK}>
Why wouldnt it, i mean your getting the wrong AF ratios going into the engine which could read out with a bad 02 but i would still replace them since you probably have over 100K on the sensors.
#9 sweeedespeed
  • 393 posts
Posted 19 February 2008 - 05:14 PM
yeah, my car's gor 150K on her. I guess it makes sense- just added my new samcos before it went to stuff on me
#10 please delete
  • 5,799 posts
Posted 19 February 2008 - 05:17 PM
QUOTE (760S @ Feb 19 2008, 12:14 PM) <{POST_SNAPBACK}>
ohh yeah replace those sensors, if you cant afford both then just do the first one, the second one is pretty much useless in a way. Atleast that way you know its not a O2 issue and you can go from there.
#11 7 VII 7
  • 22,324 posts
Posted 19 February 2008 - 05:22 PM
QUOTE (binglax09 @ Feb 19 2008, 12:17 PM) <{POST_SNAPBACK}>
the one PRE cat is for your AFR (air fuel ratio) and should help your MPG... the 2nd one is basically a way to see if your CAT is bad... I had a clogged CAT and the CEL was not on.. so go figure.
you can clean your O2 sensors by running a blow torch over them 5 times really quick alrong the sensor that goes into the piping.
#12 sweeedespeed
  • 393 posts
Posted 19 February 2008 - 10:41 PM
so since I have a new rear sensor, should I just use it in the front?
#13 7 VII 7
  • 22,324 posts
Posted 19 February 2008 - 10:44 PM
QUOTE (760S @ Feb 19 2008, 05:41 PM) <{POST_SNAPBACK}>
it will be VERY long.. you would have to ZIP tie it off... but what would you put in the rear?
#14 Karlson
    Vodka Lover
  • 7,142 posts
Posted 19 February 2008 - 10:48 PM
QUOTE (7 VII 7 @ Feb 19 2008, 07:44 PM) <{POST_SNAPBACK}>
If the car is 150k miles and o2 sensors never been changed before, and his code is not a clogged o2 sensor, then a biggest possibility that front o2 sensor gone bad.
1996 850R... gone, but not forgotten
#15 sconeman
  • 3,953 posts
  • Interests:family, cooking, making stuff, cars
Posted 20 February 2008 - 12:22 AM
QUOTE (760S @ Feb 19 2008, 03:51 AM) <{POST_SNAPBACK}>
check this out LINK TO DISCOUNT
you might be able to get a good deal on o2 sensors here. I just emailed the guy about a pair. If I find out a price I'll let you know.
#16 sweeedespeed
  • 393 posts
Posted 22 February 2008 - 05:01 AM
I got the code pulled- Rich in bank 1, code 0172. O2?
#17 7 VII 7
  • 22,324 posts
Posted 22 February 2008 - 02:41 PM
check the vacuum line that goes to the intake manifold on the passenger side... it is right near the t-stat under the coolant hose... that can tear and cause this CEL
I had it... along with misfire codes.
#18 FINN
    Pretty Boy Racing
  • 6,910 posts
Posted 22 February 2008 - 08:13 PM
QUOTE (760S @ Feb 22 2008, 12:01 AM) <{POST_SNAPBACK}>
yup.
#19 7 VII 7
  • 22,324 posts
Posted 22 February 2008 - 08:17 PM
QUOTE (FINN @ Feb 22 2008, 03:13 PM) <{POST_SNAPBACK}>
yup.
mine was the vacuum line... which is much cheaper to fix.
well a little bit cheaper
#20 sweeedespeed
  • 393 posts
Posted 25 February 2008 - 02:18 AM
yeah, I replaced the hoses with the stylin' kit a while ago, I checked the hose and it still looks good.
IPD
