Transmission Hesitation
14 replies to this topic
#1 kwells114
kwells114
  • 38 posts
Posted 19 February 2008 - 03:05 AM
2001 V70, 140,000 miles. When I'm stopped, I take my foot off the brake pedal, the transmission doesn't engage until a second or two later. Is this something I have to live with, is the tranny going bad? Is there any fix for this?
If while stopped, I shift it to neutral, then drive, then take my foot off the brake pedal, there is no hesitation, like I think it should operate.
Kev
2011 XC60, 2005 S60R 6spd, 2001 V70, 2000 V70
#2 garbergtsi
garbergtsi
  • 411 posts
Posted 19 February 2008 - 03:39 AM
there is a fix...they need to do a software upgrade to the TCM...should be under $100 to fix.
#3 nervegrind3r
nervegrind3r
  • 70 posts
Posted 19 February 2008 - 04:13 AM
QUOTE (garbergtsi @ Feb 18 2008, 11:39 PM) <{POST_SNAPBACK}>
do you how often volvo upgrades the tcm software for p2's?
I have the same problem with my tranny as well at 100k.
'02 S60 NA
#4 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
  • Gender:Not Telling
Posted 19 February 2008 - 04:19 AM
Its the stop neutral problem that destroys the trannys .
I had mine changed when I got the car at 34,000 miles
Its worth every penny to get done and should solve the problem.
I would while your there do a software upgrade on everything , that helped my car in fuel milage also .
went from 20-22 to 24+ consistanly .
Also any of you have your ETM changed or anything ?
I had mine cleaned at 42,000 and it still acts funny once and awhlle at 57,000 , what the car now has for milage.
#5 nervegrind3r
nervegrind3r
  • 70 posts
Posted 19 February 2008 - 05:08 AM
QUOTE (Chupacabra @ Feb 18 2008, 11:19 PM) <{POST_SNAPBACK}>
I cleaned out my etm this past summer, and the summer before. That resolved the bad idle problem I was having.
Also went to volvo to get etm software upgrade like 1-2 years ago, and Im pretty sure they changed the stop neutral thing. However, it did not resolve anything (from what I read it did not resolve much for others either).
I may have to drop by the stealer and get some software upgrades, but of course then I get to hear the service guy tell me "it looks like one of your end links is bad too, we can replace it for $100".
Edited by nervegrind3r, 21 February 2008 - 03:40 AM.
'02 S60 NA
#6 downunder_slangin
downunder_slangin
  • 4,289 posts
Posted 19 February 2008 - 08:31 AM
QUOTE (nervegrind3r @ Feb 19 2008, 04:08 PM) <{POST_SNAPBACK}>
I may have to drop by the stealer and get some software upgrades, but of course then I get to hear the service guy tell me "it looks like one of your sway bars is bad too, we can replace it for $100".
How about the transmission mount? see if it's worn, had mine replaced at 99.5K, big difference, got the QBM heavy duty one, can't be happier.
http://www.quickbrickmotorsports.com/prod_mounttranny.html
Check it first but.
#7 kwells114
kwells114
  • 38 posts
Posted 19 February 2008 - 11:30 AM
Thanks for your help. I'll call Vlvo today.
Kev
#8 garbergtsi
garbergtsi
  • 411 posts
Posted 19 February 2008 - 01:06 PM
im pretty sure the TCM software DOES eliminate the neutral control....if it didnt fix it they put in the wrong software....a few years ago there was a seperate part # for it but now i believe it is included in the standard upgrade...
also you will have a problem that happens when shifting from p to r, r to d or p to d. if it takes a second to engage you need a new valvebody if you want to fix that.
Why do you call them the "stealership"? would you rather pay for a new trans?
#9 kwells114
kwells114
  • 38 posts
Posted 19 February 2008 - 01:46 PM
Do you have the software part number for this fix? Thanks.
#10 2001T5
2001T5
  • 263 posts
Posted 19 February 2008 - 04:52 PM
You have to specifically tell them to turn the neutral safe off, or they won't do it. 01 automatic trannys are junk...
Eamen
2001 V70 T-5
Upgrades ~ IPD upper/lower poly engine mounts, EST CAI, IPD TCV, Stylin Hoses vacuum hoses, Bilstein HDs with TME sport springs, IPD swaybar end-links, Stealth tint. Tinted wagons rule!!
#11 nervegrind3r
nervegrind3r
  • 70 posts
Posted 20 February 2008 - 03:01 AM
QUOTE (oli_boz @ Feb 19 2008, 03:31 AM) <{POST_SNAPBACK}>
Check it first but.
I'll take a look at it again. what should I be looking for to see if its worn? I have a laundry list of this to do to my car once spring comes, I would really like for it to drive like new smile.gif
'02 S60 NA
#12 2001T5
2001T5
  • 263 posts
Posted 20 February 2008 - 06:00 PM
Grab a hold of it and twist it. If there is excessive play, then it's bad. Mine was so bad when I took the two bolts off the frame side, it almost fell off.
Eamen
2001 V70 T-5
#13 theForgottenone
theForgottenone
  • 3,977 posts
Posted 20 February 2008 - 07:46 PM
QUOTE (garbergtsi @ Feb 19 2008, 05:06 AM) <{POST_SNAPBACK}>
because they overcharge on everything else. Ask anyone on here if they don't agree with that statement. For instance, $40 for a piece of metal (oil filter adapter) while everyone else selling it for $7 or less.
#14 Fudge_Brownie
Fudge_Brownie
    Hippie Exterminator
  • 8,433 posts
Posted 20 February 2008 - 07:58 PM
$800 rear brake job, $750 timing belt job, $1000 for rebuilt turbos. Just some examples of why it's the stealership.
86 Kawasaki Gpz900R Ninja
#15 kwells114
kwells114
  • 38 posts
Posted 01 March 2008 - 01:27 PM
Took car in yesterday. They upgraded the TCM software, part number 30677036. It has made all the difference in the world. Now off to change the tranny fluid.
