BlackT5's Profile
Neutral
- Group:
- Supporting Member
- Active Posts:
- 5,656(2.11 per day)
- Most Active In:
- Performance Modifications (2830 posts)
- 22-July 02
- Profile Views:
- 9,153
- Last Active:
Today, 04:12 AM- Currently:
- Offline
Previous Fields
- Victoria, BC Canada
- Crew:
- NWC
Latest Visitors
550
07 Nov 2009 - 13:38 -
Alex McKean
05 Nov 2009 - 19:50 -
ColeW.TW
05 Nov 2009 - 13:00 -
OrEo931
04 Nov 2009 - 22:12 -
SPANKY
13 Oct 2009 - 04:11
Topics I've Started
Oil Return Lines
Posted 8 Apr 2009
I'm currently running a slightly modified stock return line on my 35R. By modified, I mean that I enlarged the bolt holes and shaved the flange down a bit since it was a tight fit. I have oil leaking from where the drain meets the turbo. I have recently replaced the gasket and tried my best to ensure the flange is flat, but I still have a drip.
I'm thinking of loosening the turbo bolts to allow the center section to swivel and then re-tightening the drain bolts to ensure that the turbo is indeed correctly clocked and the two mating surfaces are flush. Past that, i'm thinking of just making a new turbo return using the ATP oil drain flange from that I have, some braided line and maybe the end of the stock tube where it enters the block.
Thoughts? Comments?
Post your oil return setups, preferably with pics.
Help!
Posted 4 Apr 2009
So I just had a piece of the o-ring from the oil dipstick go into the pan.
I drained the oil and it didn't come out. Is this going to be a problem? Obviously it's not going to get sucked up the oil pickup, I just don't like the idea of it in there.
Rad Drain Plug
Posted 3 Apr 2009
Anyone got a busted rad sitting around? I need a drain plug. Mine works, but probably not forever.
I'm going to say from a 94-98 850, S/V/C70 turbo since they're probably all the same. I'm not sure if they changed the rad at all in 99.
My Information
- Member Title:
- NWC Rod Bender
- 33 years old
- Birthday:
- July 18, 1976
- Gender:
Contact Information
- E-mail:
- Private
Sign In
Register
Help
Find Topics
Find Posts
Display name history
Comments
BlackT5 has no profile comments yet. Why not say hello?
