JWL, on 31 January 2012 - 12:30 PM, said:
Co2 is less than 900 psi, and that is at higher temps.
The tubes on the bottom hold air. Valve releases air which pushes the slug out. I don't think that you should have a problem dropping it, even though Korean guns are said to have thinner than normal tubes.
They stay around 750-900 fps depending on tune, pellet weight, and shot number. Most only get 3-5 shots before power and POI drop. The .44 and .45 are actually more powerful than the .50 cal.
Except that .50 cal is armor piercing out to 1000 yrds and a .45 is not...
Find content
Male
Display name history
