- Volvospeed Forums
- > Viewing Profile: Bah
Community Stats
- Group Members
- Active Posts 1,664 (0.78 per day)
- Most Active In FWD/AWD 1998 and Prior (828 posts)
- Profile Views 11,592
- Member Title Level 3 Member
- Age 22 years old
- Birthday April 6, 1989
Gender
Male
Interests
Money, 850's, Computers, Women.
Computer Engineering at University of Florida. Dig it
Previous Fields
Location
Florida(Jacksonville/Gainseville)
Crew
___
Posts I've Made
In Topic: 94 850 Na Egr Removal: Bung Size And Pitch
Yesterday, 04:09 PM
Can't tell ya, I did the opposite to block off the exhaust manifold. Homedepot plugs do not fit, u need some metric thread im guessing. This works for the exhaust manifold for now though, slice the pipe with a hacksaw, and put it in a vice and bash it closed. Have mine folded over. Its a temp till someone is nice enough to fill in on it. Yea I think its a 1k ohm resistor 1/4watt
In Topic: Modified 98 T5 Will Crank- Wont Start
Yesterday, 03:40 PM
Having just gone through this, make sure your cam timing is right. I didn't remove my cam gears as there is no reason( new seals can fit over the lobes.) So if u took the gears off ensure that everything is right. My next mistake wad I put the intake manifold on wrong. Woops. My case the car would start and die immediately. Could get started with foot to floor but would die immediately. Solution found with vacuum gauge. When u redid the belt, did u rotate a few times to make sure it was on good? Might have jumped a tooth or two. Next, they mentioned behind the distributor you can put it backwards. Idk how I didn't have that issue but behind the cam sensor its the same deal. It really only goes one way, u put it in wrong and it feels wrong and doesn't really want to stay in. If ur low compression is not from timing or a crappy gauge, why did u redo the headgasket is my next question
In Topic: Front Brake Pad Recommendation?
08 February 2012 - 01:14 PM
I'm also curious the pros/cons to each of the listed pads...i know the volvo pads are made in india now i believe, ive ran mintex reds on my 93 and they've lasted damn near forever, but akebonos and PBRs, especially what 'type', i'd love opinions on.
In Topic: Apple iPad2 64GB WiFi for sale at $200 Buy it Now - USD 200.00
08 February 2012 - 01:11 PM
I am a Nigerian prince. Would you like to make a million dollars?
In Topic: IPD skid plate NIB for 850, S/ V/ C70 - USD 150.00
08 February 2012 - 01:10 PM
kev better wake teh frick frack up before he blows another oil pan for not having this
- Volvospeed Forums
- Privacy Policy
Find content
Display name history
