Ben & I started having a conversation about back pressure & what to do about optimizing flow, given that any changes are always a compromise between spool time, etc.
What I'm specifically trying to determine is where the 'choke point' is with a given setup; I would assume that it is in the turbine wheel sizing & the chamber needed to support it - but maybe not. In looking for potential alternate turbos, there are plenty that use impellers no bigger than my TD05H (56mm Major) in smaller A/R housings, that are rated for over 500HP.
I am also unclear on "trim".
Maybe I'm confusing the A/R.
For reference, my setup is: Short runner Intake. Ported '03 head. Enem 9.6mm lift cams. LG Speed header, feeding the TD05H 10cm2 (.73 A/R) 56mm impeller, 59/76mm compressor (Garrett 60-1) Exhaust is all 3", with 1.25" WG dump pipe feeding back into main pipe
The problem I see (now that I can measure EBP @ the collector) is that the pressure rises to 1 bar over IBP under higher rpm (5600-8200) WOT conditions.
I'm trying to determine if:
1)a larger A/R housing would alleviate that
2)if the exhaust impeller just needs to be larger, say 65mm (TD06) Link to my impeller
3)or if porting the wastegate opening & dump chamber would help.
I already did this (ugly, perhaps, but functional):
Originally, the WG dump was closed off, and all the flow had to make a sharp turn into the main outlet. What I have has to be an improvement, but since I never measured EBP before I installed the header, I have no idea how bad it was before. I don't experience boost creep or drop off, so I don't see how modding the WG is really going to make any difference.
Find content
Male
Display name history
