- Volvospeed Forums
- > Viewing Profile: DonutsDemise
Community Stats
- Group Lifetime Supporter
- Active Posts 4,010 (2.73 per day)
- Most Active In Off-topic/Deleted Posts (1514 posts)
- Profile Views 9,462
- Member Title Level 4 Member
- Age 25 years old
- Birthday May 7, 1986
Gender
Male
Previous Fields
Location
RVA
Crew
NEC
Posts I've Made
In Topic: Name That Noise
14 December 2011 - 09:33 AM
is there rust on the rotors? my rears sound like that when they rust up
In Topic: Boost Problem
25 November 2011 - 12:38 AM
did you check all of your intercooler hoses? maybe there is a tear in one of those that only opens under pressure.
In Topic: Car Runs Like Poop
22 November 2011 - 10:32 PM
pull your plugs and check out how fouled up they are
In Topic: Manual Transmission Cold Shifting Issues
22 November 2011 - 10:30 PM
I am in Virginia, I see you are in Canada; when you say cold do you mean well below freezing temps? because when its well below freezing my shifter is very stiff. once the transmission is hot it shifts easier though. if something was really going bad it would probably be noticeable at most temps.
22 November 2011 - 10:25 PM
did you try checking the rubber diaphragm and the spring on the compressor bypass valve (cbv)
if there is a tear in the rubber it would release pressure, if the spring is bad then at 5psi it might be allowing the valve to release pressure before rebuilding to 5psi
- Volvospeed Forums
- Privacy Policy
Find content
Display name history
