831t5r
Member Since 17 Sep 2008
Online Last Active Today, 11:23 PM
Posts I've Made
In Topic: Five Oil Leaks At Once?!?!?
25 May 2012 - 04:28 AM
Have you serviced your PVC system, make sure it isn't clogged causing all these leaks except the loose oil pan bolt.
In Topic: 06 Xc90 V8 Fuel Pump Running All The Time...
18 May 2012 - 12:39 AM
I havent done one but i believe they enter through the cowl and the seal around the cem under the cowl
In Topic: Roku
17 May 2012 - 02:03 PM
Or how about just connecting your pc to your tv. I had my comp rebuilt and have it connected to my 42 inch tv with wireless mouse and keypad. Never use it tho but can watch anything
17 May 2012 - 05:15 AM
Its actually pretty common for water to leak into the cowl.damaging the cem and/or engine wiring harness. I dont know how your service history is with your dealer but id take it in and ask for goodwill warranty for water leak issue. Our dealer has done it a lot
In Topic: Too Much Pressure In Coolant System
14 May 2012 - 02:04 PM
Try flushing out your radiator. If still happens go to a local smog shop and have them stick the sniffer in your coolant bottle see if they find any hc's like mentioned
