washdup
Member Since 24 Sep 2008
Online Last Active Today, 10:58 PM
Posts I've Made
In Topic: Rica Stg 2 With And 18T
22 May 2012 - 01:40 PM
+1 Noticeable difference after 18t install between my old RICA stage 1 and new ARD Blue. The correct tune extracts the most from the 18t. Maybe not a safety issue, as others have already said, but you will want to get the ARD blue for performance.
In Topic: 235 Whp 250 Ft/lbs Dyno: 1996 855r Auto 16t Etc.
18 May 2012 - 12:18 PM
Don't know about leaning out, but you'd likely miss the full benefits of the upgraded wheel without being tuned for it. After swapping from a 16t to an 18t in my car, the difference between the 16t tune and a new ARD Blue retune was quite noticeable. In particular, the old tune did not take full advantage of the 18t's top end. Still might be worth doing and then get the tune upgrade later.
In Topic: Front Motor Mount Stretching
18 May 2012 - 12:05 PM
Posted ImageYou mean these? My car already has them. Posted Image
View Postbergmjs, on 18 May 2012 - 01:50 AM, said:
http://volvospeed.co...3m-window-weld/
The DIY link at the top explains it more.
Guess I'll try another Volvo mount and save the current one. If the new mount also stretches too much I'll have the option to try the window-weld mod on the old one. Thanks for the info.
17 May 2012 - 04:56 PM
View Posterikv11, on 17 May 2012 - 03:36 PM, said:
Do you still have the old mount? I'd swap it in to test, it only takes a couple minutes.
Wish I did.
View Postbergmjs, on 17 May 2012 - 03:57 PM, said:
Buy some polyurethane window sealant, remove the motor mount, fill the cavity on the underside with the the poly, let cure, reinstall.
Really? Care to explain?, or point me to a thread for reference?
In Topic: Question About R-Manifold, Turbo Hot-Side And Down-Pipe Hardware
14 May 2012 - 03:31 AM
View Postande0549, on 13 May 2012 - 11:20 PM, said:
Oh, and also FCP has a price break on those flanged lock nuts if you buy the strut mount locknuts. They are the same 948645 part number:
http://www.fcpeuro.c...-mount-948645x3
:huh: The downpipe nut P/N is 977209.
Great price on the engine mount kit, but unfortunately URO parts are not known for their quality or longevity.
