laird
Member Since 18 May 2003
Offline Last Active Today, 07:51 AM
Topics I've Started
850 Sedan Rear (Non R) Wing
25 January 2012 - 06:24 PM
I have an 850 sedan rear wing with the third brake light for sale. It is currently green.
It is in good shape and if you had a green car it would be fine. Mounting brackets included, you would need some double sided mounting tape.
As is $90 shipped CONUS.
Painted any factory Volvo color additional $70
Ets Troubles Fixed
21 November 2011 - 04:37 PM
I have a 99 NA S70 that has for over a year now thrown an ETS light pretty regularly and had intermittent cruise control. I believe the code is P1047. When getting a new key cut/programmed, I asked the Volvo Tech to read any stored codes. He told me it was a "Brake Voltage Too High" message. I replaced the brake light switch to no avail and then with input from "Ihatespeedbumps", I looked at the Brake Pedal Position Sensor.
I found a great link that detailed the common failure and repair for this and went to work. http://www.volvoforu...?t=97192&page=5
It has been three months now and the car is perfect. No ETS lights and solid cruise control all for about 30 minutes work.
I had been thinking that I was experiencing the typical dreaded ETM failure but it turned out to be something very simple. The dealer wants about $120 for a new sensor but you can fix it for nothing.
IPD
