- Volvospeed Forums
- > Viewing Profile: AverageVolvo
About Me
I live in Los Angeles and I love working on and Modding 850's. You name it I can do it
1996 Emerald Green (412) 850 turbo wagon
5 Speed swap W/ M56h with Quaife Lsd. Separate reservoir(motorcycle) for clutch master cylinder
Short shift kit
Kw v2 coilovers, qbm end links
Ipd sway bars
Strut and shock braces
Ultra racing Front/Rear Lower Chassis braces.
Team Dynamic 17x7 17lbs rims,7mm Spacers,
Poly mounts on trans, engine and firewall.
Porsche Bbk, SS lines Super ate fluid.
Rolled Fenders
R Manifold
3in turbo compressor intake piping.
T04E 50 trim Divorced external Wg and Bov
Green Injectors
3in obx Downpipe Gutted Cat, 2.5 tme/ipd catback
Aem 1 gallon Methanol Progressive kit.
Custom Ard tune @ 18psi
Custom Vented Catch Can
Walbro 255lph
Gizzmo Ibc-r Rpm boost adjustable ebc.
Vdo Boost and Egt gauges
Aem wideband Afr.
Hd cbv spring
Jeweld Headlights and clear corners. With 35 watt 6000k Hids.
Ipd mesh grill.
C70 sidemarkers.
V70 upper tails
S70 paint matched door handles
R Wagon Spoiler Carbon Fiber wrapped.
Vanity plate
2 racing seats. gutted rear..
Hd battery and terminal clamps.
Pioneer Avic touchscreen double din Navigation/Stereo
Alpine in dash, doors and rear wagon pillars.
Fosgate, p3 500rms, powered by alpine 500rms in a slot ported box tuned to Spec Mounted in spare tire well..
15% tint all all windows.
Black bumpers trim.
More to Come
97 850 turbo wagon for my girlfriend. Ipd sways,Full stage 0 and an R ecu.
87 740 Na wagon. Simple,reliable, and cheap to maintain.
Giggity.
Community Stats
- Group Lifetime Supporter
- Active Posts 1,981 (1.86 per day)
- Most Active In Performance Modifications (825 posts)
- Profile Views 8,721
- Member Title Level 1 Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender
Male
Interests
Woman,Cars,Guns, Sex, Music.
And making $$$ to fund the above.
Previous Fields
Location
Los Angeles,Ca
Crew
___
Contact Information
Posts I've Made
In Topic: Question About Manual Swap
11 January 2012 - 03:33 PM
AS above mentioned. Just be sure the 98 transmission had an external slave cylinder bracket
In Topic: E85 Conversion
13 December 2011 - 08:48 PM
Just use some TOLUENE(114 OCTANE) for an octane booster. No more than 1-5 gas ratio(20%)
In Topic: T40e 50 Trim On Lpt
16 November 2011 - 08:31 AM
To4e 50 trim with .48 ar is what you meant to say
and an Atp ultimate internal wg will not give you any boost problems until you go over 18-20 psi. IMO
A good ebc will tame the boost. I tamed the wild 19t with 7cm with no hassles. once I had an ebc. and the to4e was much easier IMO.
But yeah the 18t is definitively better suited for your needs.
As far as china bay turbos. Godspeed seem to be relatively reliable. and their customer service is excellent. should you have a problem under their 1 yr warranty.
- Volvospeed Forums
- Privacy Policy
Find content
Display name history
