I think with your "R" your stock springs should be ok.... I went with KONI FSD on my 98 c70 and stayed with stock springs... I had the IPD sway bar installed from before and the combination really gives you a ride that is comfy and handles really well in the corners... my goal was not to sacrifice comfort for a performance shock setup and the FSD + stock springs did just that... if you don't have the IPD sway bars you *must* get these... huge difference....
the FSD specifically helped bump steer and made the car feel more neutral... also in corners I was able to apply more power since the shocks have such high pressure they keep the wheels glued to the road...
I'm curious how low the IPD springs will make the car and if they are even a match for the FSD.... I think the R springs you have are already low and you should stick with them... just go for shocks and sways and you'll be smiling!
c70pete
Member Since 31 Jan 2004Offline Last Active Today, 05:01 AM
Find content
Not Telling
Display name history
