- Volvospeed Forums
- > Viewing Profile: Aequitas_Veritas
Community Stats
- Group Lifetime Supporter
- Active Posts 9,071 (3.19 per day)
- Most Active In Off-topic/Deleted Posts (1870 posts)
- Profile Views 16,832
- Member Title Blue Calipers&Balls
- Age 27 years old
- Birthday May 29, 1984
Gender
Male
Previous Fields
Location
Orange County, cali
Crew
___
363
Excellent
User Tools
Latest Visitors
Topics I've Started
Need A 13T/16T Turbo To Rebuild
03 February 2012 - 05:36 PM
Hey guys, I am looking for a 13t/16t for Spanky to rebuild. I already bought one turbo off a member that turned out to be damaged internally and cannot be used. Looking to pay less then $150. What do you have?
How To: Install A Basic Alarm Like The Pros
30 December 2011 - 08:01 AM
Let me first point out that I am not one to let other people work on my car EVER. In fact, I can count on one hand the number of things I have had someone else’s help on for things that have to do with my car. I have let someone else install and do tire related stuff, I have let someone else do an alignment, I let someone else lay the black suede on my headliner (after I screwed it up once), and I let someone else polish the parts on my engine bay (cause screw that). Its not that I don’t trust other people, I just know I would do a better job because I care more about the outcome then they do. And nothing on my car is half assed. I like to do mods only once and not have to redo them later when they break.
So that being said, I got a Viper 5901 alarm system for my car last year as a Christmas present from my parents.. A year has gone by and I have not been able to find a shop that I would trust to do a proper job that I would be happy with. So I knew I had to do it myself. Since I have a manual swap, and have watched Pras run his car up a curb and almost into a side of a building showing off his remote start to me and left the car in gear, I decided I really didn’t need a remote start here in southern California. I realize now since im not hooking up the remote start I could have gotten a Viper 3303 which is the same alarm but without remote start and can be found for about $180-$200.
So after downloading every wiring guide I could find, including the DEI one, the Volvo one, 2 more from the 12volt.com, and the Hayes manual. I set out to find the wires that I have to hook up. And because no one of these guides makes it easy for you to figure out what wires to tap, and because I had to trace these wires out on every diagram, I am now going to make an easy write up for how to install a basic alarm better than any alarm shop could even do it by tapping only one wire and soldering it instead of crimp connectors. Done right this will last the lifetime of the vehicle. However you should always test the wire colors I provided with a meter first before tapping them to ensure they are correct. I assume no responsibility for any damage caused due to these instructions. I am however, 100% sure of their accuracy for 1996 850s.
However for my security I am not going to show almost any pictures because I don’t want people to know where I installed it in my car. But I am going to tell you exactly what wires to tap to get parking light flash, lock/unlock, door sensor, trunk sensor, hood sensor, tilt sensor, and glass break sensor.
You will need
Wire Location
12+volt constant Input (+) Tap any red wire with 12+volts constant (Most red wires)
Ground (-) Tap any black wire
Siren Output (+) Goes to the siren under your hood/ wiper cowl. I put mine under my wiper cowl, just remember to face it slightly down so water doesn’t collect in it.
Trunk Pin trigger Input (-) Red block, Red connector, pin 11, blue-brown wire
Instant trigger Input (-) Some alarms can have multiple triggers from other things such as backup batteries that instantly trigger the alarm, mine shared this trigger with the trunk pin
Door Trigger Input (-) Red block, Blue plug, Pin 6, Yellow-White wire
Parking Light Output (+) Yellow block, Blue plug, Pin 8, White wire
Unlock Output (-) White block, Blue plug, Pin 8, Blue-Brown wire (This wire must be double pulsed to unlock the car, I had to set that in my alarm settings)
Lock Output (-) White block, Blue plug, Pin 10, Yellow-Grey wire
Hood Pin Goes to a hood pin you install under the hood, here Is the custom mount I did for mine Here are some pics of the bracket I made:
You will also have to run wires up to you dome light for the controller antenna where you can hide the module in there. I attached it to my ceiling above my passenger side of the dome light.
Of course all my connections are soldered and heat shrunk on. I pulled each pin out one by one and used a razor to cut away the wire insulation and wrapped the alarm wire around the Volvo wire and soldered it, then slipped a piece of head shrink on the end, lighter and reinstall the pin into the plug. Here are some pics of after I was done:
I also bought a glass break sensor module and 2 window modules that I will be getting next week so that I can add them onto this write up for those that want to roll their windows up as they get out of their cars. They also add 1 touch to every window.
Hopefully this guide will help those people out on the fence about doing it themselves.
You will need
- quality solder 60% tin/ 40% lead .8mm diameter with a rosin core. NO that stuff you has left over from sweating the water pipes will not do in this application LOL.
- High quality solder iron
- 3m Super 33+ electrical tape 66ft roll about $5-6 each
- 4", 8" black zip ties
- Digital Multimeter
- wire loom in 1/4" and 3/4" sizes
- wire fishing tool, generic wire hanger will do most of the time or I used solid core copper wires (very stiff)
Wire Location
Southern California Beach And Burgers Event Photos
20 November 2011 - 06:11 PM
Meet pictures, sorry there are so much of my car, I am a little partial:
And pictures of the beach we went down to see afterwords
- Volvospeed Forums
- Privacy Policy
Find content
Display name history
