- Volvospeed Forums
- > Viewing Profile: Posts: JHEIII874T5M
Community Stats
- Group Supporting Member
- Active Posts 14,845
- Profile Views 23,310
- Member Title Level 6 Senior Member
- Age 26 years old
- Birthday February 15, 1986
Gender
Male
Previous Fields
Location
Boca Raton, FL.
Crew
CFL
27
Neutral
User Tools
Posts I've Made
In Topic: So I Still Have Boost Fade...
26 March 2012 - 01:57 PM
Probably see this
26 March 2012 - 01:35 PM
I'll be honest with you... being on stock exhaust in a tuned car is really not advisable. You are running increased boost in this case, more heat, and judging by the way you drive -- probably doing extended full throttle pulls. I can pretty much guarantee you that there are already hairline cracks in your turbine housing and possibly where it mates to your manifold.
The hammer comment I was being serious, but one check you should really do is to just pull your downpipe off (3 bolts). Have a look inside your turbine housing for any cracks near the wastegate.
If you're down here in South Florida, getting an exhaust fabricated is really straight forward and there are some really talented exhaust shops down here.
23 March 2012 - 05:31 PM
Get rid of your stock exhaust. Check your turbine housing for cracks since you've been pushing it hard. Hammer down on the wastegate arm to make sure it's sealed. Also check your wastegate pressure to make sure it's in line.
In Topic: Arp Head And Rod Bolts
23 March 2012 - 02:57 PM
If anyone wants ARP set, I can order them directly... if I remember it was around $200 for a set. Not on here as often, but email or PM always works.
- Volvospeed Forums
- Privacy Policy
Find content
