bob850
Member Since 30 Jun 2004
Offline Last Active Today, 12:58 AM
Posts I've Made
In Topic: My Dash Repair Experience Thus Far
03 May 2012 - 05:21 PM
View PostBtownVolvo, on 02 May 2012 - 02:52 PM, said:
They are the stops that you stick either inside of drawers to keep from slamming or even under coffee tables. Just stick them on the sides of the box and there ya go!
Hmmmm... I still don't get it. Are you putting them on the front face of the box which contacts the glovebox door? Sorry for being dense.
In Topic: My Ipd Strut Brace Install
02 May 2012 - 07:12 PM
Pretty sure. I ordered it directly from Tasca.
02 May 2012 - 01:22 PM
View PostBtownVolvo, on 01 May 2012 - 06:19 AM, said:
Yea I don't think I've ever seen a glovebox that doesn't have at least 1 shattered hole. This could cause some glovebox squeak, but I just solved it by putting in some slightly beefier rubber "door stops" to make it shut tighter and that stopped any noise.
Could you elaborate on the "door stops"?
30 April 2012 - 01:12 PM
Just an update, everything is back in now. The dash is a little quieter over bumps, and I feel better that the reinforcement is there on the tabs for future crack prevention (hopefully).
One remaining problem is that many of the glovebox screw points are broken, it was beyond epoxy. The glovebox plastic is pretty junky. I might order a new glovebox at some point, might just leave it as is. If I get a new one, I'll probably try to apply some epoxy to it to beef up the mounting points before installing.
26 April 2012 - 01:28 PM
Got the main part of the dash back in last night, will finish the steering wheel, upper pad, etc, tonight.
You guys were correct on the second hole. After measuring the bolts and clearances through the firewall, I did in fact need the second hole on the back of the mounts to allow the screws to poke through past the retaining nuts, not much, but enough that the holes were needed. The middle two mounts were pretty easy to drill, but for the two outside ones, it was tricky to get the drill in there without removing the aluminum strips. For those, I ended up drilling a small pilot hole, then a medium hole, then the 3/8" hole. Starting with the 3/8" hole wouldn't work due to the angles in there, and I don't have a right-angle drill. Anyway, I eventually got it done.
The main dash feels pretty tight so far, I think the epoxy reinforcement on the lower side arm mounts (down by the footwells) helped to reduce some play and squeakiness as well.
