All Activity
This stream auto-updates
  1. Yesterday
  2. Last week
  3. Hi, I’m pretty new to the Volvo scene, and it’s been really hard for me to find info on any kind of mods or anything in particular with my car, I’m an owner of a 99 Volvo c70 2.4l 5 cyl, it’s the convertible, not the coupe:( I was wondering where to start and how high I can take the performance on it, it’s a b5254t engine, am I able to throw a bigger turbo on it? And what kind of hp can I get out of it before I crack the block?
  4. Earlier
  5. Hi all, having problems in cruise control mode. 1996 Volvo 850 Turbo Wagon - Automatic - Engine Type 57 - 2.3 L - 127,000 miles Lately with Cruise Control I am getting an RPM surge between 300 and 500+ RPM at random times even when the CC switch is ON and NOT engaged. Getting surges when running under CC also. At a stop with foot on brake it sometimes surges like that and is quite frankly pretty scary. This does NOT happen when I turn off the CC switch. Only when it is on. No surges with the CC switch in the off position. Any idea's where to troubleshoot this? Any help would be greatly appreciated. Thanks in advance, Clark
  6. It’s amazing how something as small as a dent can become a daily annoyance—especially in busy places like Lynnwood, where tight parking lots and stray carts are part of everyday life. Many drivers assume fixing those dents means days in the shop and a pricey paint job. But that’s not the only option. More locals are choosing paintless dent repair Lynnwood WA for fast, affordable, and non-invasive results. It preserves your factory finish and restores your car’s sleek look—without fillers or repainting. See the full before‑and‑after dent repair gallery to discover how effortless dent repair can really be.
  7. That little dent on your car door might seem harmless—until you see it every single day. Whether it came from a tight parking spot, a rogue grocery cart, or a surprise hailstorm, traditional body shop fixes often mean days without your car and a repair bill that stings. That’s why many drivers are choosing paintless dent repair instead. It’s a faster, non-invasive way to restore your vehicle’s original look without fillers, sanding, or repainting. See the full before‑and‑after dent repair gallery to find out how easy and effective this solution can be.
  8. Give your Volvo a clean, OE-style upgrade with our newly designed hood cowl snow caps—built for both looks and protection. Our caps press into place in seconds and feature an optional grille insert to help block leaves and debris from entering your cowl vent. Choose between two rugged, weather-resistant materials: black ASA or ASA-CF. Check out more photos and details in the listing! https://vprintsus.etsy.com/listing/4297487297
  9. not sure I always try and keep a spare around just in case... I would scour the countryside for a good used unit ...
  10. I did add a pic, strange. Now found this in my profile...You have used 7.8 MB of your 7.81 MB attachment limit. Sorry, no image then. I used to have gauges and buttons there, too, when I had airride. That was completely hand formed around them by welding hundred small plastic pieces into shape and then textured the surface to kinda look like plastic bumper.
  11. Hello Everyone, Like many people, I'm having problems with my bevel gear. Machining new splines on the shaft in Europe seems complicated....The addresses I had have closed... I found a site that sells new shafts, but not for my model! https://lbmautoparts.com/fi-fi/tasauspyörästöjen-osat/land-rover-range-rover/crown-wheel-pinion-land-rover-volvo-front-differential/62932 Do you have any addresses for this by any chance? Do you know who made the bevel gears for the VOLVO AWD P80? Yann
  12. Got a pic? I thought about doing it that was as a couple locals have as well for gauges. I need to revist this project and do some finishing touches still.
  13. Nice! looks 3D printed? I was working couple months ago on similar project. Just oldschool way - template, mold, fibreglass, sanding... then glued on some leather for final look.
  14. FYI: saw this today at the Sherwood Pic N Pull in Metro Portland OR area www.picknpull.com/check-inventory/vehic ... 04S2153094 Car has a manual 5 speed in it. Not sure if it's original or it was swapped in but able to shift it into all 5 gears (+ R) sitting in the yard. I don't need it but thought someone might be looking for one? Aren't these hard to come by? External slave cyl. Moderator: feel free to move this to more appropriate thread if needed. Hope someone gets this before the car is crushed..!
  15. Hey everyone, greetings from France I just discovered this forum through the Motronic 4.4 tuning thread and I wish I had found it sooner haha Anyway, here's the deal : I am nearing the end of my engine swap which is a B5254T (from an '97 850, Manual LPT 193hp, Motronic 4.4) in my 740 Wagon. When trying to start it, it started right up, ran fine for a whole second or two, than died right away. I'm pretty confident I have an immobiliser issue, which I hoped this engine didn't have but here we are. I was looking for somebody to do an immo off on my ECU, but then I found out there's a ton of ressources to do it yourself, so I thought I'd give it a shot. However, I can't find a LPT 193hp .bin file with immo off, so I was wondering if anyone knew where I could find one ? I found plenty of HPT .bin files, but I'd rather just stick to flashing the ECU with an immo off .bin rather than messing with other parameters to make a HPT work for a LPT. Bit of a mouthful, sorry about that. I'll add a few pictures of my project to make it more interesting 😆 Thanks in advance !
  16. Listing: https://vprintsus.etsy.com/listing/1831997858 Upgrade your Volvo 740, 760, 780, and 940 series vehicles with VPrints premium dash cupholder solutions. Our innovative system replaces the ashtray with a durable, single-piece design featuring up to 3 cupholders. Five configurations of this product are available in two materials/finishes: please review the listing images to determine what's best for you. Additionally, at your request PRIOR to ordering this product can be fully customized with different colors, cup sizes, gauge mounts, and other features. Installation takes minutes with no tools required. Note this cupholder does utilize the latching mechanism off the ashtray (PN 3519274), thus an ashtray is needed to install this part. Additionally, if your 12V plug cubby (above the ashtray) is loose, it is HIGHLY recommended that you also purchase our "Volvo Dash Cubby Repair Kit (740/940 series)", otherwise the cupholder may not stay secure. This product is crafted from thermal, UV, and impact-resistant ASA & ASA-CF (carbon fiber) plastic. Note only certain variants are compatible with manuals.
  17. Hello all. just wanted to give all you fellow Volvo folks a heads up that my C30 Polestar #83 is up for sale on Cars & Bids. I'm the original owner with a very low mileage of 38,100. Please check it out and if you know of someone looking let them know. I will still have my 240 wagon and my V70 wagon just no longer have a garage we down sized. Love our Volvo's!!! The auction ends this Friday at 4:00 PM EDT. If you are bidding best of luck. Here is the link: 2013 Volvo C30 Polestar Limited Edition VIN: YV1672MK4D2308516 for Sale - Cars & Bids
  18. Yeah now that im about to jump back into working on the car I mineaswell. Need to pop the dash cover off anyways to replace the dead cluster, so ill route some nicer cables through the dash to the back of the headunit that ill be replacing soon as well. Need to fish all the old dash cam wiring out as well since my blackvue finally fell apart after what feels like 5-6 years. (The unit pictured has a forward facing camera on it, and has a rear back up cam that doubles as a rear dash cam). Have a few things on the shelves to put on over the next couple of months as well. Was fun working on the car for the short time I did over the weekend, forgot how it felt.
  19. Really well honestly, and the engine bay is so nicely done I took photos so I can redo mine haha.
  20. Finally somewhat finished the center dash speaker holder for a heads up display. Need to make some tweaks, and fish the wiring to the back of the radio for a cleaner look, but it worked out for my drive to a meet over the weekend.
  21. Some how this post isnt archived lol. Anyways, saw the old ride over the weekend.
  22. Since the other thread is archived. Touched the s70 a bit, and then installed some more lighting in the garage after doing some organizing of parts. Made a list of stuff to buy to do a stage 0 and replace.
  23. Thats pretty exciting and awesome!
  24. Bud its a free phone, dont fuck it to hard.
  25. It passed inspections two weeks ago! Didn’t disappoint at all. Few notes from the tech. Still a lot to do but passing inspections is a huge relief. A lot more pictures on my Instagram; @jodelj81 💚
  26. The issues raised with the new iPhone, such as durability concerns, might echo past controversies like "bendgate," but they’re not exactly media-frenzy material. Every year, iPhones continue their trend of incremental upgrades—better performance, sleeker design, improved cameras—much like Samsung or LG. However, iPhones are more than just smartphones; they are cultural icons and fashion statements, similar to the hype surrounding new Air Jordans. At BrandsCollective, we understand the allure of blending technology with style. Just like you elevate your wardrobe, choosing the latest gadgets reflects personal expression and staying ahead of the curve
  1. Load more activity
