Jason R. Posted September 17, 2005 Report Share Posted September 17, 2005 Once the computer has been cleared and reset, how long should it take for it to run its non-continuous monitor tests? If my question doesn't make sense, here is the background:Last week I failed an emissions test. The likely culprit was the nearly completely destroyed little rubber vacuum elbow connected to the passenger side of the intake manifold. I replaced it and had the memory reset to clear the check engine light. One week later, I went back to get the emissions tested again. Before he even ran the test, he hooked something up to the ECU and got the following reads under the "non-continuous monitor tests" section:Catalyst - Not CompleteHeated Catalyst - Not supportedEvaporative System - Not CompleteSecondary Air System - Not CompleteA/C Sys Refrigerant - Not SupportedOxygen Sensor - Not CompleteOxygen Sensor Heater - Not CompleteEGR System - Not Supported.The emissions guy was tryinig to tell me that I just haven't waited long enough since the computer was reset for it to have a chance to run those tests again. But its been nearly a week, the car has been driven probably 75 miles (about 40 of them on the freeway). Do you think I really need to wait longer or is something else wrong. What do I do??? :( Link to comment Share on other sites More sharing options...
the underlørd Posted September 18, 2005 Report Share Posted September 18, 2005 What do I do??? you go buy an OBDII code reader and reset the codes right before you get the emissions tested. Link to comment Share on other sites More sharing options...
rodrigo Posted September 18, 2005 Report Share Posted September 18, 2005 is this also the same way to get the 'service' light reset? Link to comment Share on other sites More sharing options...
billr99 Posted September 18, 2005 Report Share Posted September 18, 2005 is this also the same way to get the 'service' light reset?Nope. Need special Volvo-specific tool for that. IPD has one for about $160. Or pull the light all together. Link to comment Share on other sites More sharing options...
Bay13 Posted September 18, 2005 Report Share Posted September 18, 2005 What do I do???This is a problem that a Lot of Volvos are having across the USA as the various emission stations are connecting tools to see if the ready-ness codes are set. If they are set that means there are no codes and if there is no smoke out the exhaust there is no need to dyno the car. Problem is that for all the ready-ness codes to reset on the Volvo ECU it is a royal pain. I'll try to find the driving cycle and procedures to force reset the ready-ness codes. It's a long complicated driving cycle that has to be done twice. Link to comment Share on other sites More sharing options...
Guest Guest_Jason R._* Posted September 18, 2005 Report Share Posted September 18, 2005 This is a problem that a Lot of Volvos are having across the USA as the various emission stations are connecting tools to see if the ready-ness codes are set. If they are set that means there are no codes and if there is no smoke out the exhaust there is no need to dyno the car. Problem is that for all the ready-ness codes to reset on the Volvo ECU it is a royal pain. I'll try to find the driving cycle and procedures to force reset the ready-ness codes. It's a long complicated driving cycle that has to be done twice.Thanks. Do you know if the ready ness codes actually need to be reset in order for me to pass the emissions? In other words, I can't tell if the emissions guy is telling me that I will fail because of the ready-ness codes arren't reset or because he doesn't want to hook me up to the dyno because he thinks there is actually something wrong with the car. Can I just tell him to hook it up? He was mumbling something about the fact that since more than two of codes aren't ready, he can't pass me. Just wondering if maybe I should go elsewhere. Link to comment Share on other sites More sharing options...
Bay13 Posted September 18, 2005 Report Share Posted September 18, 2005 It is apparent that your state reads the readyness codes and if they are not ready you fail. Common in many states. You need to get the readyness codes to say set. Link to comment Share on other sites More sharing options...
Jason R. Posted September 20, 2005 Author Report Share Posted September 20, 2005 Once the computer has been cleared and reset, how long should it take for it to run its non-continuous monitor tests? If my question doesn't make sense, here is the background:Last week I failed an emissions test. The likely culprit was the nearly completely destroyed little rubber vacuum elbow connected to the passenger side of the intake manifold. I replaced it and had the memory reset to clear the check engine light. One week later, I went back to get the emissions tested again. Before he even ran the test, he hooked something up to the ECU and got the following reads under the "non-continuous monitor tests" section:Catalyst - Not CompleteHeated Catalyst - Not supportedEvaporative System - Not CompleteSecondary Air System - Not CompleteA/C Sys Refrigerant - Not SupportedOxygen Sensor - Not CompleteOxygen Sensor Heater - Not CompleteEGR System - Not Supported.The emissions guy was tryinig to tell me that I just haven't waited long enough since the computer was reset for it to have a chance to run those tests again. But its been nearly a week, the car has been driven probably 75 miles (about 40 of them on the freeway). Do you think I really need to wait longer or is something else wrong. What do I do??? I found this on the internet, is from an older Volvo Service bulletin. It worked perfectly even though it took me about an hour to do. What a pain! Affected vehicles: Motronic 4.4, equipped with an automatic transmissionMotronic 4.3, equipped with an automatic transmissionOBD II Readiness Codes: Revised Reset InstructionsBackgroundThe MY 1996, 1997 and 1998 Volvo 850/S70/V70/C70s require an extendeddriving period in order to reset readiness codes from INCOMPLETE toCOMPLETE. When verifying an emission related repair, the TRIP identifiedin Section KKKK of the Engine Management System Service Manual TP2308202 M 4.4 or Section EBU of the Engine Management System ServiceManual TP 2301202 M 4.3 may not allow all of the diagnostic monitors torun.The following instructions, which supersede TRIP instructions containedin the above referenced service manual, will exercise all of thediagnostic monitors on these models. As long as no diagnostic troublecodes have been stored, the readiness codes will be set to COMPLETE uponcompletion of two consecutive trips driven according to theinstructions.Introduction 1This on-road driving sequence will allow all of the diagnostic functionsan opportunity to run. After two correct, consecutive TRIPS, thereadiness codes should be set to COMPLETE, provided no diagnostictrouble codes have been stored.General Instructions 2Engine temperature at start must be below +50°C (122°F).Air conditioning (A/C) must be off during idle periods. A/C compressoractivation during the Evap diagnostic may interrupt the Evap test.Select a suitable route where it is possible to safely stop at the sideof the road. Obey all traffic regulations and posted speed limits.Trip Instructions 3^ Start engine^ Move gear selector to Drive^ Accelerate gently to 1500 - 2000 rpm^ Drive for 6 minutes at 1500 - 2000 rpm^ Safely stop the car and idle engine for 70 seconds with Drive engaged^ Accelerate to 1600 - 2000 rpm^ Drive for 6 minutes at 1600 - 2000 rpm^ Stop the car and idle engine for 70 seconds with drive engaged^ Accelerate to at least 45 mph, drive for 5 minutes at 1800 - 2200 rpm^ Stop the car and idle engine for 60 seconds with Drive engaged^ Accelerate to at least 45 mph, drive for 4 minutes at 1800 - 2200 rpm^ Stop the car and idle engine for 60 seconds with Drive engaged^ Drive the car to the location where it will be parked^ Move gear selector to Park^ Stop engine Finished Link to comment Share on other sites More sharing options...
Bay13 Posted September 21, 2005 Report Share Posted September 21, 2005 That looks like the procedure, and you have to do it twice if I remember correctly. Link to comment Share on other sites More sharing options...
