Keaton85 Posted April 4, 2007 Report Share Posted April 4, 2007 Ok so i figured we should start a topic on a price sheet for all the parts and or outsourced labor to the machine shopHere is a short list of the items we should cover so this goes out to anyone with some numbers! I will add them to the list as they are posted.RodsOEM - $114 ea.R-sport rods: $100 ea.PistonsMahle(OEM): $54 ea. / OS1: $84 ea.RingsBearingsMain OEM: $170Rod OEM: $130 GLYCO: $40Gaskets/SealsSetElring: $80 (PN:275234)Head:Cams:Cam CoverElring: $10 (PN:1161059)Plug Holes:RMS:FMS:Oil Pump:Water Pump:Intake Manifold:Exhaust Manifold:throttle Body:Oil Pick-up:MachiningCleaning:Flux:Deck:Hone:Bore:Blue Print:Window:Thanks -Aja D. Link to comment Share on other sites More sharing options...
fromtheshadows Posted April 4, 2007 Report Share Posted April 4, 2007 Ok so i figured we should start a topic on a price sheet for all the parts and or outsourced labor to the machine shopHere is a short list of the items we should cover so this goes out to anyone with some numbers! I will add them to the list as they are posted.RodsPistonsringsBearingsGasketsMachiningThanks -Aja D.Part prices are a phone call away. Machining cost vary greatly by location and shop. Maybe a complete list of what needs to be done during a rebuild, part prices, and what is optional might be better. For prices at my local machine shop it really depends on how much work they have to do that day and how fast you need it done. Dont forget windowing the block ;) Link to comment Share on other sites More sharing options...
gdizzle Posted April 4, 2007 Report Share Posted April 4, 2007 Ok so i figured we should start a topic on a price sheet for all the parts and or outsourced labor to the machine shopHere is a short list of the items we should cover so this goes out to anyone with some numbers! I will add them to the list as they are posted.RodsPistonsringsBearingsGasketsMachiningThanks -Aja D.Stock rods w/ bolts around 114 bucks eachR-sport rods 100 bucks each w/ boltsSPM rods are around 250 each mark IIRC, probably wrong thoughOEM pistons are 54 for STD bore, 84 for OS1Bearings are $170 bucks for the main bearing kit and rod bearings are 130 for OEM geniune volvo partsGaskets you need a lot...head gasketgasket compoundoil pump o-ring and gasketRMS5 o-rings for the spark plug channels in the headoil sump o-ringswater feed line gasketwater pump gasketexhaust manifold gasketsintake manifold gasketcam sealsetc etc etc. I have a complete list at home, i'll up date later. Link to comment Share on other sites More sharing options...
Keaton85 Posted April 4, 2007 Author Report Share Posted April 4, 2007 Thanks Greg!! I will update that later as i have to run down to the shop and throw some heads on my Subaru :( Link to comment Share on other sites More sharing options...
fromtheshadows Posted April 4, 2007 Report Share Posted April 4, 2007 Good price for pistons. Mahle piston sets (OEM) frpm fcpgroton are $500.00 for for up to + .40mm. That price does include rings which would be another $100.00 if seperate, but once you pay for shipping you might as well hit the dealer. Link to comment Share on other sites More sharing options...
gdizzle Posted April 4, 2007 Report Share Posted April 4, 2007 Good price for pistons. Mahle piston sets (OEM) frpm fcpgroton are $500.00 for for up to + .40mm. That price does include rings which would be another $100.00 if seperate, but once you pay for shipping you might as well hit the dealer.Only place you can get them right now is dealer only. FCP CAN NOT get them right now. The OEM piston ring kit is per piston though, so thats about 80 bucks per piston.. Link to comment Share on other sites More sharing options...
Keaton85 Posted April 12, 2007 Author Report Share Posted April 12, 2007 So i got a quote to clean, flux, deck, bore, hone, and check/polish the crank for $408, i lost the piece of paper that had each price for every item so i will post it when i find the damn thing. I will probably pay them to do another cleaning after they get the machine work done because it tends to leave shavings and what not through the engine. Link to comment Share on other sites More sharing options...
kildea Posted April 13, 2007 Report Share Posted April 13, 2007 why so much for the bearings? fcp has them for $95.00 for the main bearing set and $82.00 for the rod bearing set for the b6284 motor. Link to comment Share on other sites More sharing options...
thelostartof Posted April 13, 2007 Report Share Posted April 13, 2007 hahahha Stock No. 274478Part No. 274478Brand: GLYCO Connecting Rod Bearing Set $40 ya'll are getting ripped the f offoh and Stock No. 275234Part No. 275234Brand: ELRING Cylinder Head Gasket Set $80takes care of MOST of the gasketsStock No. 1161059Part No. 1161059Brand: ELRING Valve Cover GasketAnerobic Sealer $10^^ that is the crap you use ALL Over the engine so get 2-3 tubes of it just because it is cheapStock No. 6842347Part No. 6842347Brand: ELRING Cylinder Head Bolt $3 eachwhile you are @ it Stock No. 3545696Part No. 3545696Brand: MERA Oil Pressure Sender $8oh and yes i can get all of this stuff +++++ lots more if anyone needs anything Link to comment Share on other sites More sharing options...
kildea Posted April 13, 2007 Report Share Posted April 13, 2007 Stock No. 274478Part No. 274478Brand: GLYCO Connecting Rod Bearing Set $40that's friggin' sweet ... Link to comment Share on other sites More sharing options...
Keaton85 Posted April 13, 2007 Author Report Share Posted April 13, 2007 I would rather go OEM if im going through all this time and money rebuilding the engine. Inless there is proof that the aftermarket bearings hold up better, but as for as im concerned the OEM ones are proven. Link to comment Share on other sites More sharing options...
thelostartof Posted April 13, 2007 Report Share Posted April 13, 2007 I would rather go OEM if im going through all this time and money rebuilding the engine. Inless there is proof that the aftermarket bearings hold up better, but as for as im concerned the OEM ones are proven.last i heard glyco IS oem .... just like MANN filters are OEM tho they make MANN ones and volvo ones with differnet boxes/labelssame thing for a LOT of parts the dealers sell as remember VOLVO does not make these parts in house as they outsourced EACH part to a company that sepcialized in those parts .. same reason all of the sensors are BOSCH sensors and not volvo ones ...just like if you go to the dealer and buy gaskets they will sell you VOLVO parts but it was all made by elring and dealer just marks it up anywhere from 100-400%not like i should know any of this because you know it is not like my supplier is the one who sells most of the parts to the dealers ..... oh snap .. wait we do Link to comment Share on other sites More sharing options...
Keaton85 Posted April 13, 2007 Author Report Share Posted April 13, 2007 True but is anyone 100% that this is the company that makes the bearing for Volvo? If so i will definitely go with this or that company on any parts. Is there anywhere else other then eeuroparts.com that sell all of these parts? Link to comment Share on other sites More sharing options...
Keaton85 Posted April 13, 2007 Author Report Share Posted April 13, 2007 What about these? http://www.eeuroparts.com/productdetail.as...1&code=7921They have a different part number? Link to comment Share on other sites More sharing options...
thelostartof Posted April 13, 2007 Report Share Posted April 13, 2007 FCP groton sells all of these partsi also sell all of these partsWhat about these? http://www.eeuroparts.com/productdetail.as...1&code=7921They have a different part number?that is the old part number for them when i search via that one it comes up with the number i gaveoh and the dealer list for those rod bearings IS only $50 so ya'll might want to check your local dealer on those prices Link to comment Share on other sites More sharing options...
