quick s70 Posted July 6, 2008 Report Share Posted July 6, 2008 Last week our wagon wouldn't start. I got the 314 cam sensor code. I removed the sensor, cleaned it (because Pick N Pull didn't have one), reinstalled it and cleared the code. After that the car started and ran fine the whole week. I even took it on a 400 mile run 2 days ago and it ran fine. Yesterday my wife calls me from work and says the car won't start again. She works in a prison and I can't go inside to work on it so we were going to have it towed home. I decided to walk her through the steps of checking and clearing the codes to see what would happen. She got the 314 code and that was it so I had her clear it and the car started right up. Why would clearing the code allow the car to start? I figured if the sensor was dead that was it but obviously its not wiped completely out if its still running and the only thing that we did was to clear the codes. I guess thats a good place for anyone to start if their stuck with an issue like this, might save you the trouble of waiting and paying for a tow home. Link to comment Share on other sites More sharing options...
AlvinL Posted July 6, 2008 Report Share Posted July 6, 2008 Thanks for sharing.DTC information 3-1-4ConditionIf the ECM does not receive any signal from the CMP sensor for 2.4 engine revolutions, DTC 3–1–4 is set at the next attempt to start the engine.Substitute value At the next start attempt, the fuel injection and ignition sequences will be absent.Possible source-Signal lead short circuited to ground or voltage.-Break in signal, voltage or ground lead.-Contact resistance in connectors.-Defective CMP sensor.Fault symptom Engine does not start Link to comment Share on other sites More sharing options...
quick s70 Posted July 6, 2008 Author Report Share Posted July 6, 2008 Cool, now I understand. Chances are the sensor is going out but the computer shuts down the fuel and ignition systems on its own because of the code being present. I guess I'll change out the sensor soon then. thanks. Link to comment Share on other sites More sharing options...
