Oreo931 Posted May 6, 2006 Report Share Posted May 6, 2006 First you need the projectors. I got a sick deal on these used from the forums on HIDplanet.com for $30 bucks shipped with bulbs. They go for around $50 shipped w/ bulbs new from HIDplanet. They are Bosch mini H3 50mm projectors.Just took em out of the box.Projectors next to the s/v70 foglight housingsThe round piece you see in this picture is part of the housing that holds the bulb and contains the reflective material. It just unclips from the housing easily.In order to make sure the projectors would fit in the housing I measured them to make sure there would be enough room. It measured just over 2" and the foglight housing depth was even deeper ~ close to 2.5"This is the backside of the housing here is a better shot of the housing with the bulbs holder piece not connected. This is the piece (the circular one) that needs to be dremeled. It is very thick plastic so it takes a lot of time with the dremel. You can see the metal piece inside the circular one, you must pry that out with a screwdriver, you wont need it anyways so dont worry about messing it up, it just makes the job easier when dremeling so sparks dont go shooting.these are both of the inner housing pieces next to each other, one is dremeled while the other isnt. The way i dremeled it was i cut off the raised circular part first (the one that the bulb goes into) then cut a large circle (the one pictured) for the projector to go into. I cut it just large enough for the projector to go into while the bowl still remained on the outside (you will see what i mean in the test fit pictures)test fittingtest fittingfront shottest fit the whole thing togetherNext i used this stuff that i have used in all of my retrofits...it hardens like concrete but can still be screwed into and does not fall apartI used about half a stick of it and molded it around the housing as pictured..This way I can screw the projector into the housing easily.I waited for the plastic cement stuff to dry and then put the projector into the housing and screwed it into the freshly hardened plastic. everything is together! I know i didnt write anything about the wiring thats because as of now its pretty shoddy until I come up with some better ideas. I have extra ballasts laying around that I plan on using for a 3000k application on these things...I will try to get some cutoff pictures when I get a chance as wellIf you have any questions feel free to ask :) Link to comment Share on other sites More sharing options...
Volvoson Posted May 6, 2006 Report Share Posted May 6, 2006 Everything is up and running I just need to type up the instructions and resize the pictures. .Sweet :) Link to comment Share on other sites More sharing options...
mikie Posted May 6, 2006 Report Share Posted May 6, 2006 I'll be waiting...cool thanks! Link to comment Share on other sites More sharing options...
NGB Posted May 6, 2006 Report Share Posted May 6, 2006 Awesome! Hows the output? Get some good wall shots. Link to comment Share on other sites More sharing options...
exexpat Posted May 6, 2006 Report Share Posted May 6, 2006 Sweet! Those look like fog light projectors. If so, the output will be the same as a stock 850 / C70 light. Link to comment Share on other sites More sharing options...
NGB Posted May 6, 2006 Report Share Posted May 6, 2006 Sweet! Those look like fog light projectors. If so, the output will be the same as a stock 850 / C70 light.I would hope the beam pattern would be better.They are Hella mini projectors, if i remember correctly. Link to comment Share on other sites More sharing options...
HPTDoh Posted May 7, 2006 Report Share Posted May 7, 2006 Cool writeup! :P Link to comment Share on other sites More sharing options...
Jaxx Posted May 7, 2006 Report Share Posted May 7, 2006 woah! you used a fork to install them?! :-Pcan't wait man. Link to comment Share on other sites More sharing options...
Oreo931 Posted May 9, 2006 Author Report Share Posted May 9, 2006 TTT Its done!!! Link to comment Share on other sites More sharing options...
ViperVette Posted May 9, 2006 Report Share Posted May 9, 2006 sweet man! Thats a great writeup... and those ain't no cell phone pictures! NOICE! Almost gives the hopeless like myself hope... Link to comment Share on other sites More sharing options...
Oreo931 Posted May 9, 2006 Author Report Share Posted May 9, 2006 lol yeah, no cell phone pix this time Link to comment Share on other sites More sharing options...
Mesoam Posted May 9, 2006 Report Share Posted May 9, 2006 why aren't the projectors in the middle of the housing? was that done intentionally? Link to comment Share on other sites More sharing options...
Oreo931 Posted May 9, 2006 Author Report Share Posted May 9, 2006 yes...Its just the way the housing are built. Link to comment Share on other sites More sharing options...
the underlørd Posted May 9, 2006 Report Share Posted May 9, 2006 wall cutoff pic? Link to comment Share on other sites More sharing options...
NGB Posted May 9, 2006 Report Share Posted May 9, 2006 why aren't the projectors in the middle of the housing? was that done intentionally?The S70 fogs are like that from the factory. Link to comment Share on other sites More sharing options...
