Volvospeed Forums
Removing Fuel Tank
turbomoose
Of course, just to be "safe" disconnect the battery. And no smoking. And do it in a well ventilated area.
If you break something, or kill yourself, of course, that's not my fault.
1997 850 T5 Sedan 158K :arob:
Tools needed:
Jack rear end of car up, place on secure jack stands:
Remove the trunk carpet and plastic thing the carpet mounts on top of, set aside:
Remove the two covers for the fuel pump and fuel level sender:
Disconnect the fuel pump, ABS sensors, Fuel level sender, and pressure sensors:
The fuel tank is secured to the car by 3 bolts:
Middle rear of the tank:
Right Front of the tank:
Left rear of the tank near exhaust pipe:
There is a circlip of sorts that needs to be removed from the fuel filler:
Removed:
Push the rubber surrounding the filler neck into the quarter panel:
Place a high lift large enough floor jack under the middle of the tank to support it while you lower:
Lower slowly:
oh yeah... if you're working on rough concrete, it helps to toss an old picnic blanket down first. This is much better to use than the trunk floor, since you can EASILY wash the blanket.
Continue to lower slowly:
Further push the fuel filler neck into the quarter panel:
Lift tank off of floor jack and remove the fuel lines, noting which line goes to which port. There's also one vent line:
This is the weepy mess:
I believe my leak was from the fuel level sender. But then the hose clamps were lose too.
CLEANED:
Epoxied these two connections just for funsies:
Replaced:
All done:
:D
It wasn't difficult to do at all, and now, hopefully I'll be able to fill it up FULL and not have a stinky garage. We'll find out in a few hours once I go fill 'er up!
It's been a few hours now, ...and my small garage has no gas smell at all! WOOHOO!! Within minutes I could smell gas after a fill up.
I think the gas station pump may be screwing people. I filled up with 18.1 gallons of premium :blink: Which may be possible. My INFO computer thing said 10 miles till empty.
I'm averaging 24.5 MPG. 445 Miles I drove on the last tank but I did a LOT of idling.
dude, i really hope you replaced that rubber hose there....that was the culprit in my fuel leak...couldn't fill up all the way either.
Nope, I removed it when I did the epoxy on the blue fitting and checked it out well, and it was in great shape. I know that hose has been an issue to some, but mine was leaking, or rather still leaks from the sender and pump gaskets. They're being ordered. So Im going to do a fuel pump write up when I replace the gaskets.
19.3 gal capacity
Very nice write-up you've made there.
  • Create New...
