Black Betty Posted November 30, 2008 Report Share Posted November 30, 2008 I finally got the chance to install the yazaki cluster in my R tonight. Everything works great but...When the needle hits 40mph the needle drops to zero and stops reading anything, slow down to below 40 and it reads again. What could be the problem here? Link to comment Share on other sites More sharing options...
prasamin Posted November 30, 2008 Report Share Posted November 30, 2008 speed sensor?what year is your R?what year did the Yazaki come from? Link to comment Share on other sites More sharing options...
Black Betty Posted November 30, 2008 Author Report Share Posted November 30, 2008 speed sensor?what year is your R?what year did the Yazaki come from?96, no idea what year the cluster came from but everything works fine, except for the speedo, side note that might matter my abs module is bad Link to comment Share on other sites More sharing options...
Black Betty Posted November 30, 2008 Author Report Share Posted November 30, 2008 speed sensor?what year is your R?what year did the Yazaki come from?i think i know what it is...Once i hit 40+ and it stops showing a speed it also stops counting the milage. Im guessing the yazaki cluster is different from the other clusters and uses a wheel to both count the milage and show the speed.... Link to comment Share on other sites More sharing options...
mune237 Posted December 1, 2008 Report Share Posted December 1, 2008 .... side note that might matter my abs module is badthis is not good, and is probably causing some if not all of your problems Link to comment Share on other sites More sharing options...
Black Betty Posted December 1, 2008 Author Report Share Posted December 1, 2008 this is not good, and is probably causing some if not all of your problemsbut my question is why didn't it cause problems with my vdo? and its not like the abs light turns on and boom no speed its at a certain speed abs light or not.Also i'll mention when my abs light would come on with the Vdo cluster so would the tracs, on the yazaki they happen independent of each other its odd. And i dont think i've ever seen them both at the same time. Time is scarce for me im at school without my car so on holidays i work on it. If i can over christmas break ill try to pull the abs module and see if that helps but i have my doubts Link to comment Share on other sites More sharing options...
