TurboS60 Posted December 2, 2008 Report Share Posted December 2, 2008 For those of you who have flushed their transmission, I got the IPD kit and it says to connect the clear tubing to the upper line going into the radiator (with the green clip holding it in). But i heard that this is wrong and the tubing should be connected to the actual outlet itself instead of the line that clips into it. So whats the proper way for this? Link to comment Share on other sites More sharing options...
FistFull Posted December 2, 2008 Report Share Posted December 2, 2008 good luck with your flush...please keep us posted on how it went...my trans is next in line of things to do... Link to comment Share on other sites More sharing options...
1999_V70 Posted December 2, 2008 Report Share Posted December 2, 2008 What? Pull the tube out and connect the hose to the tube, easy easy. Link to comment Share on other sites More sharing options...
TurboS60 Posted December 2, 2008 Author Report Share Posted December 2, 2008 What? Pull the tube out and connect the hose to the tube, easy easy.I was told you connect the hose to the OUTLET, not the tube itself. Link to comment Share on other sites More sharing options...
TurboS60 Posted December 2, 2008 Author Report Share Posted December 2, 2008 I was told you connect the hose to the OUTLET, not the line itself. Link to comment Share on other sites More sharing options...
1999_V70 Posted December 2, 2008 Report Share Posted December 2, 2008 Well as someone who's done it multiple times, I'm TELLING you to connect to the hose. Why would you connect it to the outlet? :lol: Link to comment Share on other sites More sharing options...
nervegrind3r Posted December 2, 2008 Report Share Posted December 2, 2008 bro, push in the green clip from both sides and remove the lineinsert the plastic clear tube you got from ipcturn on carwatch that dirty trans fluid rush outstop the car when bubbles come outfill tranny fluid through tranny dipshit holdrepeat till fluid comes out reddone dealimages below: Link to comment Share on other sites More sharing options...
1999_V70 Posted December 2, 2008 Report Share Posted December 2, 2008 Well as someone who's done it multiple times, I'm TELLING you to connect to the hose. Why would you connect it to the outlet? Whoops, I'm going to have to eat my words. I was wrong, looks like the P2s reversed the way the trans cooler works. Good to know. Link to comment Share on other sites More sharing options...
JesterKB Posted December 3, 2008 Report Share Posted December 3, 2008 Whoops, I'm going to have to eat my words. I was wrong, looks like the P2s reversed the way the trans cooler works. Good to know.I have a P2 (01 V70 T5a), and I flushed about a year ago just like it was shown in the pictures including the speed tape to get a better fit The hose is the return line from the cooler, so the flush line goes in the radiator to capture the old stuff. Good luck with the flush let us know how it goes.Jerr Link to comment Share on other sites More sharing options...
phishfriend Posted December 3, 2008 Report Share Posted December 3, 2008 again....pardon my n00bnessdoes this car have a filter or is it just flush and fill? :rolleyes: Link to comment Share on other sites More sharing options...
TurboS60 Posted December 3, 2008 Author Report Share Posted December 3, 2008 Thats what i needed to know.So what did you do with the line thats disconnected? Nothing comes out of it right? Link to comment Share on other sites More sharing options...
1999_V70 Posted December 3, 2008 Report Share Posted December 3, 2008 Thats what i needed to know.So what did you do with the line thats disconnected? Nothing comes out of it right?It's going to drip a little bit, but otherwise don't worry about it. Link to comment Share on other sites More sharing options...
dongle Posted December 3, 2008 Report Share Posted December 3, 2008 How much transmission fluid is stored inside the radiator? I need to replace my radiator today and don't have time to do a flush at the same time. I cannot find any 3309 locally and don't have time/ money to get it from Volvo with Tim out for knee surgery.I'm wondering if I'll be safe losing that little bit of fluid and rolling like that for a week or so until I can do a proper flush on the cheap. Link to comment Share on other sites More sharing options...
harleyhv Posted December 4, 2008 Report Share Posted December 4, 2008 bro, push in the green clip from both sides and remove the lineinsert the plastic clear tube you got from ipcturn on carwatch that dirty trans fluid rush outstop the car when bubbles come outfill tranny fluid through tranny dipshit holdrepeat till fluid comes out reddone dealimages below:Ok... couple of questions:Now that we know where the oild will come out....Can someone give me a pic of where I have to pour in the trans oil?If I would install a transmission oil cooler, should I install it before or after the radiator? Link to comment Share on other sites More sharing options...
phishfriend Posted December 4, 2008 Report Share Posted December 4, 2008 "Can someone give me a pic of where I have to pour in the trans oil?"between the engine and radiator.....right center below the hoses......theres a little dipstickpull it out....fill it thereits also where you check the level Link to comment Share on other sites More sharing options...
