Volvospeed Forums
1998 V70 Xc From The Beginning... to the End
lookforjoe
I'm gonna put all my build mods in one thread - hard to keep track of all the separate closed threads..
The begining - Oct '07 misc stuff first... I'll try to list in chronological order.
17" pegs
Rear Spoiler, EST dual exhaust, "cross country" delete..
EST ABM's & SharpHID's lo & fogs
"R" door panels
Rear seat heaters
20% tint & pillar blackout (3M 73602 3" black tape)
poly torque mount & new style firewall mount
horn relocate
18" pegs, 302mm brakes
Amp & subwoofers
Tombone endlinks
Bumper, grille paint & new emblem
"R" sill plates
Tailight tint
1st dyno.. 223WHP/291tq (runfile 238)
lower shores performance MBC
3 gauge pod
EGT, Boost, Wideband, intake temp
IPD BBK
Raceway Park
V70XR_0995.png>
best time (19T - running 15psi (TCV)
Eyelids...
M66 conversion
NOTE: Not all DM Flywheels are the same - you need an S60/V70R DM flywheel for the R clutch to fit.
dual mass / S60R clutch
30783258 kit
8636105 T/O -Slave
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70ManConversion0002.jpg
the trans
trans bracket mods - prototype
revision
revised 02/2012
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/M66%20Brackets%20Shifter%20Parts/IMG_0198.jpg
revised summer 2012
remove cable pins w/ bolts
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70ManConversion0009.jpg
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/M66%20Brackets%20Shifter%20Parts/V70XCM66linkage.jpg
custom left side supprt bracket
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/M66%20Brackets%20Shifter%20Parts/IMG_0789.jpg
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/M66%20Brackets%20Shifter%20Parts/IMG_0788.jpg
bevel gear
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70ManConversion0006.jpg
connecting sleeve
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70ManConversion0003a.jpg
pedals
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70ManConversion0010.jpg
shifter
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70ManConversion0011.jpg
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70customShifter0004.jpg
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/V70customShifter0007.jpg
custom shift bushings.. (vo 1378153, cut down to fit)
FMIC & Catch Can
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/Breather%20Modifications/CatchCanInstall0009.jpg
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/Breather%20Modifications/CatchCanInstall0011.jpg
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/Breather%20Modifications/CatchCanInstall0008.jpg
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/IC%20Plumbing/XCv70FMIC0002.jpg
battery sideways.. stock tray cut down, new hole drilled in tray to use existing mount points
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/IC%20Plumbing/XCv70FMIC0020.jpg
harness clearance..
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/IC%20Plumbing/XCv70FMIC0023.jpg
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/IC%20Plumbing/XCv70FMIC0014.jpg
modified splash pan
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/IC%20Plumbing/XCv70FMICsplashPan0002.jpg
http://i27.photobucket.com/albums/c190/huseinholland/CarMods/IC%20Plumbing/XCv70FMIC0011.jpg
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/XCV70springclean0011.jpg
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/XCV70springclean0012.jpg
Water Injection...
aquamist fittings for solenoid
home depot 1/4" fittings for Shurflo pump connections
fabricate harness
aquamist 7mm nozzle
aquamist reservoir fitting, aquamist 6mm line
160psi Shurflo pump in frame rail - 1/2" to 1/4" fittings
injector solenoid activated indicator
Wiring Diagragm
  • Create New...
