Volvospeed Forums
Head Bolt Torque
EricF
I can't find my Haynes manual, so I was just wondering what the torque figures are for the 850 head bolts... And are they TTY bolts?  I hope not  :ph34r:
cylinder head:
the upper section is 12 ft lbs
lower section is
stage 1 15ft lbs
stage 2 37 ft lbs
stage 3 37 ft lbs plus another 130 degress.
They can be reused. If you had the Volvo manual, it lists a length the bolts can be before you have to get new ones. I've found over time re-used once is OK, the second time around you are better off getting new head bolts cause they are close to being too long.
  • Create New...
