Volvospeed Forums
Ac Cooling Problem
artizen
Anyone out there have intermittent AC outages?
Here's a typical scenario:
Around town:
Start car, AC works fine, perfectly cold enough for a Texas summer
Drive around town for around 20-25 minutes, the air gets warm
If I shut off the car, wait about 5 minutes, when I start, the AC gets cold again
Driving highway:
As long as the AC is working when I hit the onramp (and no traffic), the AC stays cold
The minute I hit traffic, it goes back to getting warm after around 20 minutes
All light on AC buttons are working correctly. Fan is blowing air. This happens if the air recirc button is on or off.
Already spent time (3 weeks) and money ($400) at the local Volvo dealership. They could not fix the problem.
This is a VERY annoying problem. Any help/suggestion would be greatly appreciated.
Thanks in advance,
artizen
taken from the excellent a/c writeup on this very site:
"Very often the first sign that the system is malfunctioning is the rapid cycling of the compressor clutch because of a loss of refrigerant"
loss of refrigerant, id put money on your evaporator, plus might be the most commonly failed part on these cars... unfortunately its quite $$ to replace. ask that dealership or check ur invoice to see if the evap was touched, i doubt it was for 400 dollars, since its pretty much in a steel safe behind/under the dash. (sarcasm about teh steel safe but you get the idea).
Artizen,
My 1994 850 with 153k miles suffered the same problem. I replaced the evaporator, checked everything and the problem continued exactly like yours.
After a lot of testes and research on many different forums I finally found out what the problem was and had it corrected last week. Most probably your A/C compressor is cycling of under certain conditions because the thermal protection switch built into the compressor is telling it to cycle off because compressor temperature is too high. And why is it too high? Because due to wear, the gap between the compressor magnetic coil plate and the clutch plate has increased beyond the maximum which is 0.6mm. Under this circunstances, the magnetic field generated by the clutch coil under, is slightly weakened by the high ambient temperature, just enough to make the clutch be unable to engage. As it tries to make it engage, temperature on the compressor rises above normal and the thermal switch does its act. You may find on the forums that a solution to this problem is to override the thermal switch, which works, but will lead to a more serious failure of the clutch later on.
The correct solution is to carefully remove the compressor ( no need to evacuate the system or undoing the connections) then with the compressor lowered from the frame under the car, remove the clutch plate and adjust the gap by removing one or more of the shims behind it so that proper gap is acchieved once the clutch plate is mounted back. See this:
http://www.volvoclub.org.uk/dc/dcboard.php...id=11445&page=2
Before you do anything, just to make sure this is your problem, Measure the gap with a feeler gauge with engine off. Then do a second test: with the car and a/c on during the occurrance of the problem, that is when the a/c stops cooling, using a large screw driver and carefully tap the center of the compressor clutch plate. Be careful of the serpentine belt and pulleys. If the clutch engages, that is the smoking gun. You found the problem.
Good Luck!
Luis
  • Create New...
