SIAMBLUE Posted February 28, 2005 Report Share Posted February 28, 2005 Just wondering what you guys are running and at what gap?I have just installed some Denso's IK22 but the gap was factory set at .32 or .8mm,Just wondering from the Pros out there should i close the gap up to .7 as this is the standard gap,As i don't want to run lean and throw a piston.Gary. Link to comment Share on other sites More sharing options...
gdizzle Posted February 28, 2005 Report Share Posted February 28, 2005 Just wondering what you guys are running and at what gap?I have just installed some Denso's IK22 but the gap was factory set at .32 or .8mm,Just wondering from the Pros out there should i close the gap up to .7 as this is the standard gap,As i don't want to run lean and throw a piston.Gary.←it depends on wether or not your car is tuned. If it is stock, it should .028, tuned .025/6/7. Really just play around with it see what works best. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted February 28, 2005 Report Share Posted February 28, 2005 This happens a lot to them. I have personally seen 3 in two engines do this. I use 1 dollar champion plugs now. Link to comment Share on other sites More sharing options...
Guest Guest Posted February 28, 2005 Report Share Posted February 28, 2005 This happens a lot to them. I have personally seen 3 in two engines do this. I use 1 dollar champion plugs now.←charles, do u use platinum or copper? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted February 28, 2005 Report Share Posted February 28, 2005 charles, do u use platinum or copper?←Copper Link to comment Share on other sites More sharing options...
SIAMBLUE Posted February 28, 2005 Author Report Share Posted February 28, 2005 wow that is serious,The car had Bosch platinums before,Just fancied a change of plug,will keep a plug spanner in the boot just in case. Link to comment Share on other sites More sharing options...
Guest Guest Posted March 1, 2005 Report Share Posted March 1, 2005 I've had the NGK Iridiums pregapped at .30 with ST ChipNo problems whatsoever...although I am not jumping on the gas pedal either.Maybe in the future I'll try out something a little tighter...Now...on the other hand... I havent noticed any benefits either (MPG or Personal feel of the car)Maybe on a dyno or some other tests might show some tangible evidence Link to comment Share on other sites More sharing options...
GShyneDM Posted March 1, 2005 Report Share Posted March 1, 2005 Oops, thats me up there... now wonder my post count is so low... :rolleyes: Link to comment Share on other sites More sharing options...
MrWinkey Posted March 1, 2005 Report Share Posted March 1, 2005 Copper is the best "performance" choice in my book but once again it all depends on what your mods you have ,how the car is tuned and ultimatley how much boost your running! The copper wears out much faster but burn's the best? (now that's my opinion only?) ;) Link to comment Share on other sites More sharing options...
turbor850 Posted March 1, 2005 Report Share Posted March 1, 2005 This happens a lot to them. I have personally seen 3 in two engines do this. I use 1 dollar champion plugs now.←Part number ? :lunchbox: Link to comment Share on other sites More sharing options...
Che'_Moderator Posted March 1, 2005 Report Share Posted March 1, 2005 Part number ? ←IK22, you tune your car yet? Link to comment Share on other sites More sharing options...
Volvoboi24 Posted March 1, 2005 Report Share Posted March 1, 2005 This happens a lot to them. I have personally seen 3 in two engines do this. I use 1 dollar champion plugs now.I had similar results with bosch platinum +2 plugs (advertised to be good for 60k miles) in my old '94 wagon for about 2 years (25k) before it started misfiring a lot, since then I switched back to copper plugs(15k changing intervals) and havent had a problem since. Link to comment Share on other sites More sharing options...
volflo Posted March 1, 2005 Report Share Posted March 1, 2005 i was never that much into gapping my plugs. i mostly ran beru or volvo oem and didnt gap them at all. worked fine tho.so with my set up what gap (in mm please) would you suggest with volvo oem resp. denso iridium 22?thanks.p.s. does it make any difference if a msd or oem coil is hooked up? Link to comment Share on other sites More sharing options...
turbor850 Posted March 1, 2005 Report Share Posted March 1, 2005 IK22, you tune your car yet?←Champion Plug IK 22 I meant Champion part # Link to comment Share on other sites More sharing options...
gdizzle Posted March 1, 2005 Report Share Posted March 1, 2005 IK22, you tune your car yet?← :lol: Link to comment Share on other sites More sharing options...
